[pgrouting-users] pgrouting - TSP problem
Balázs Csikós balazs.csikos at gmail.com
Tue Apr 17 18:12:36 EDT 2012
Dear All!
I'm using the pgrouting TSP function for the shortest distance calculation.
My problem is: if I use different order of magnitude numbers (1.xxx,
10.xxx, 100.xxx, etc.) for "source_id", my results are SO MUCH different
too, while the "source_id" shouldn't affects the shortest distence results
(if I know well)...
What I else tried, I was setting in the pgAdmin conf file the "Genetic
Query Optimizer" settings' parameters in ALL WAYS, but my results was the
same, always the same, so NOTHING HAPPENED!
Do you have any ideas to solve my problem?
Thanks for Your help!
All the Best,
Balázs
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120418/675d7733/attachment.html
More information about the Pgrouting-users mailing list
