[pgrouting-users] pgRouting in the cloud?
Daniel Kastl daniel at georepublic.de
Thu Feb 23 23:05:22 EST 2012
pgRouting works with PostgreSQL 9.x
I compiled it on Open Suse. And I built packages for Ubuntu 11.10 64bit
because I needed them.
I didn't upload to Launchpad repository yet, because I wanted to test more
first and then had no time.
Packages are here for now:
http://build.eq8.georepublic.net/build/oneiric-amd64_result/
Usually issues are with boost paths, CGAL and libgmp ... not with
PostgreSQL.
Some compile issues and how to solve them are already mentioned in tickets.
If packages work on AWS or not I don't know though.
Reports about success and failure are welcome.
Daniel
On Fri, Feb 24, 2012 at 11:07 AM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Hi All,
> Yes, I think pgRouting running on Postgres 9 is a requirement. Well I
> don't have Postgres 9 installed here, and have not tried it, I am also not
> away of any issues in this regard.
> If you are trying to install from binary packages, there may be an issue
> that the package builders have not build packages for it. If I can find
> some time to create a Virtual Machine I'll try to install postgres 9 and
> pgrouting and report back, but don't hold your breath, as I have been crazy
> busy lately.
> Regarding the next release, we know we need one, but having lost our
> developer and release manager, we are in the process of trying to get some
> other people involved and this takes time. If you have time and want to
> volunteer I'm sure we can come up with taks suited to your skills.
> Thanks,
>  -Steve
> On 2/23/2012 6:33 PM, Max Weninger wrote:
>> Hi
>> Sorry - didnt noticed that this is postgres 9
>> I think "official" support for postgres 9 is coming in
>> the next pgrouting release but the "experts" here should give
>> an answer to that.
>> Regards
>> max
>> On Thu, 23 Feb 2012 23:14:13 +0000
>> James David Smith<james.david.smith at gmail.**com<james.david.smith at gmail.com>>
>>  wrote:
>>  Hi all,
>>> Thanks for the replies, and especially to Max for the link to the
>>> installation guide. Unfortunately that's beyond me, I work in Windows
>>> at the moment and have only limited experience of using linux.
>>> 'Opening a terminal window' was about as far as I got before not
>>> really knowing what to do! I guess that the terminal window would need
>>> running from within the AWS service too, so even if I knew how to open
>>> a terminal window and start entering those commands I'd first need to
>>> somehow be able to do that from within AWS - which I don't. Also I
>>> note that the AWS PostgreSQL cloud service is for PostgreSQL 9.0 and
>>> 9.1, whereas the instructions you gave Max seem to relate to
>>> PostgreSQL 8.4 - and hence wouldn't be compatible...?
>>> Sorry for being a bit of a newbie - still learning! This would all be
>>> pretty cool if I only had the know-how.....!
>>> James
>>> On 23 February 2012 22:59, Max Weninger<max.weninger at gmail.**com<max.weninger at gmail.com>
>>> wrote:
>>>> Hi
>>>> On Thu, 23 Feb 2012 22:45:07 +0000
>>>>  wrote:
>>>>  But I am less sure about pgRouting. There aren't any guides that I
>>>>> can find.
>>>> Try this one
>>>> http://workshop.pgrouting.org/**chapters/installation.html<http://workshop.pgrouting.org/chapters/installation.html>
>>>> Regards
>>>> max
>>>> ______________________________**_________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120224/21bf7b8b/attachment-0001.html
More information about the Pgrouting-users mailing list
