[pgrouting-users] Shortest Path TRSP
Max Weninger max.weninger at gmail.com
Mon Feb 27 19:48:31 EST 2012
Hi
Just noticed this change.
Great! - Now I can remove some code
where I did something similiar :)
Regards
max
On Mon, 27 Feb 2012 17:03:11 -0500
Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> Also, there is another version of the API that does take edge_ids for
> the start and end of the route rather than node_ids. You would call
> it like this:
> Using the edge + percent is better because it allow you to take into
> account restrictions and onewayness of the start and end edges that
> can not be done with the version you are using. This was a recent
> update to git so you might want to pull an updated versions.
More information about the Pgrouting-users mailing list
