[pgrouting-users] Problem with way restrictions in shooting star if you have more then one rule for an edge
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jan 11 20:48:32 EST 2012
Max,
Great! we have tested this pretty extensively but we also appreciate you
testing and feedback. One area that we need to get better at is setting
up a standard testing framework that we can apply before releases to
verify that we have not broken any code. We have discussed the need for
this, but not the details of how to do it yet.
My thinking is along the lines of we create a database of graphs, test
cases, expected results and have a test runner that runs the test stores
the results in a table and reports the results.
An alternative to this would be to create a collection of files that
each represent some series of tests like the above, and can be loaded
run evaluated, and dropped. This might be easier to manage that one huge
file.
It would be easy to automate the running of the tests using a Perl or
Python script to run each test in sequence and summarize the results.
I also think that it is probably a good idea for the developers to
create unit tests so that they can verify their code before it is
wrapped into postgres so we can separate algorithm issues from
integration or changes in the postgresql API that might break stuff.
Anyway if you have good simple test cases, I would love to get them and
if you are interested in support pgRouting buy helping build some of the
above, I would be happy to work on designing something that is easy to
build and and maintain.
Thanks for the report.
OH and yes the last edge is always -1, but I forget the rationale for
why at the moment.
-Steve
On 1/11/2012 8:13 PM, Max Weninger wrote:
> Hi again
> It does not only look good - its perfect :)
> All my turn restriction "testcases" work as expected
> and give the correct routing.
> Thanks a lot for the work and if you need some help
> e.g for testing just give me a note.
> Regards
> max
> On Thu, 12 Jan 2012 02:02:48 +0100
> Max Weninger<max.weninger at gmail.com>  wrote:
>> Hi
>> Tried the new trsp code and it looks good :)
>> I havent tried complex turn restrictions though
>> But just a quick question:
>> Is it normal that it always returns -1 as the last edge id?
>> regards
>> max
>> On Wed, 11 Jan 2012 11:28:38 -0500
>> Stephen Woodbridge<woodbri at swoodbridge.com>  wrote:
>>>> I will take a look at the "new" code asap :)
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
