[pgrouting-users] Shortest Path Shooting-Star Ignore Reverse Cost
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 30 14:47:14 EST 2012
Jorge,
I have posted a few times on this problem, you can check the archives.
The short story is the shooting star is broken. I think the last version
that worked is 1.03. In my posts is also some information on a new
algorithm turn_restricted_shortest_path (trsp) that is in a branch. The
current code in a git branch works but is likely to see changes before
it is released, but we do not have a release plan yet.
-Steve
On 1/30/2012 2:30 PM, Jorge Eliécer Osorio Caro wrote:
> Im having a issue when try to calculate the shortest path using turn
> restricctions this functions ignores the reverse_cost param.
> here the SQL:
> |SELECT
>      FROM
>          shortest_path_shooting_star(
>              'SELECT
>                  routing.network.segment as id,
>                  routing.network.source,
>                  routing.network.target,
>                  routing.network.length as cost,
>                  routing.network.reverse_length as reverse_cost,
>                  routing.network.x1,
>                  routing.network.y1,
>                  routing.network.x2,
>                  routing.network.y2,
>                  routing.network.rule,
>                  routing.network.to_cost
>              FROM
>                  routing.network',
>              -- node_from, node_to
>              15365,
>              15366,
>              --15242,
>              false,  -- directed
>              true-- reverse_cost
> this generate that route:
> http://cl.ly/242E2T0A2C410F1S0F3g
> that method generate the route but it ignores the one_way restriction ,
> the restriction is ok, but take a route where ignores that.
> now in the next image i need the marked red lines are the correct route
> because the 15229 and 15228 has both ways.
> http://cl.ly/3t2O38343F0F0C0o3P2c
> here how look my table:
> id source target cost reverse:cost rule to_cost x1, y1, x2, y2
> 15245 9082 9150 0.02 100.00021 15214 101.00021 -74.79981 10.94605
> -74.7996 10.94605
> how i cant fix that i compiled the last version of pgrouting from git repo.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
