[pgrouting-users] Shortest Path Shooting-Star Ignore Reverse Cost
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 30 16:20:48 EST 2012
The turn restrictions are handled differently in TRSP. You need to have
a table like:
target_edge_id (int4), to_cost(float8), via_path (text)
This is a replacement for the rule and at the moment
    via_path := reverse(rule)
so if your rule = 1,2,3,4 then via_path = 4,3,2,1
I think that this will eventually change to be consistent with
shooting_star and the rule.
I believe that the way to interpret this is to apply the to_cost if the
current edge it target_edge_id and prior edge was 4, and 3 before that,
and 2 before that, and 1 before that. So the cost would NOT be applied
given this rule if the path was current_edge, 4, 3, 7 for example.
You may have multiple rules for a given target_edge_id.
-Steve
On 1/30/2012 4:00 PM, Jorge Eliécer Osorio Caro wrote:
> Hi Steve,
> I compile that version but i dont know very well the params that i need
> to send to:
> now we have via_path, means that edges where i can have access? its in
> replacement of rule?
> now we have that parameter to:
> sql text,
> source_id integer,
> target_id integer,
> directed boolean,
> has_reverse_cost boolean,
> turn_restrict_sql text)
> turn_restrict_sql what i need to pass there?
> i have something like this:
> SELECT * FROM turn_restrict_shortest_path( 'SELECT
> routing.network.segment as id, routing.network.source,
> routing.network.target, routing.network.length as cost,
> routing.network.reverse_length as reverse_cost, routing.network.x1,
> routing.network.y1, routing.network.x2, routing.network.y2,
> routing.network.rule as via_path, routing.network.to_cost FROM
> routing.network', -- node_from, node_to 15365, 15366, --15242, false, --
> directed true, -- reverse_cost '¿?' )
> thanks steve.
> 2012/1/30 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
>     Jorge,
>     I have posted a few times on this problem, you can check the
>     archives. The short story is the shooting star is broken. I think
>     the last version that worked is 1.03. In my posts is also some
>     information on a new algorithm turn_restricted_shortest_path (trsp)
>     that is in a branch. The current code in a git branch works but is
>     likely to see changes before it is released, but we do not have a
>     release plan yet.
>     -Steve
>     On 1/30/2012 2:30 PM, Jorge Eliécer Osorio Caro wrote:
>         Im having a issue when try to calculate the shortest path using turn
>         restricctions this functions ignores the reverse_cost param.
>         here the SQL:
>         |SELECT
>              FROM
>                  shortest_path_shooting_star(
>         'SELECT
>                          routing.network.x1,
>                          routing.network.y1,
>                          routing.network.x2,
>                          routing.network.y2,
>                          routing.network.rule,
>                      FROM
>                          routing.network',
>                      15365,
>                      15366,
>                      --15242,
>                      false,  -- directed
>                      true-- reverse_cost
>         this generate that route:
>         http://cl.ly/ 242E2T0A2C410F1S0F3g
>         <http://cl.ly/242E2T0A2C410F1S0F3g>
>         that method generate the route but it ignores the one_way
>         restriction ,
>         the restriction is ok, but take a route where ignores that.
>         now in the next image i need the marked red lines are the
>         correct route
>         because the 15229 and 15228 has both ways.
>         http://cl.ly/ 3t2O38343F0F0C0o3P2c
>         <http://cl.ly/3t2O38343F0F0C0o3P2c>
>         here how look my table:
>         id source target cost reverse:cost rule to_cost x1, y1, x2, y2
>         15245 9082 9150 0.02 100.00021 15214 101.00021 -74.79981 10.94605
>         -74.7996 10.94605
>         how i cant fix that i compiled the last version of pgrouting
>         from git repo.
>         ______________________________ _________________
>         Pgrouting-users mailing list
>         Pgrouting-users at lists.osgeo. org
>         <mailto:Pgrouting-users at lists.osgeo.org>
>         http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users mailing list
