[pgrouting-users] Shortest Path Shooting-Star Ignore Reverse Cost
Jorge Eliécer Osorio Caro jorgeliecer.osorio at gmail.com
Mon Jan 30 17:47:48 EST 2012
Steve,
This is my route:
http://cl.ly/2v3G05442o3h2H0G2L0l
i have restricted turn going from 9151, 9082.
how i need to set this in my table restricctions.
SQL:
drop table if exists routing.route;
create table if not exists routing.route(
nid serial not null
) with oids;
Select AddGeometryColumn('routing', 'route', 'geometry', '4326',
'LINESTRING', 2);
insert into routing.route(geometry)
SELECT
routing.network.geometry
FROM
SELECT
FROM
turn_restrict_shortest_path(
'SELECT
routing.network.segment as id,
routing.network.source,
routing.network.target,
routing.network.length as cost,
routing.network.reverse_length as reverse_cost
FROM
routing.network',
 -- node_from, node_to
9151,
9082,
--15242,
false, -- directed
true, -- reverse_cost
'SELECT
routing.restrictions.target_id,
routing.restrictions.to_cost,
routing.restrictions.via_path
FROM
routing.restrictions'
) as route inner join routing.network on
route.edge_id = routing.network.segment
Table looks like:
target_id   to_cost   via_path
9082        1000      9151, 9083
i missing somehting?
2012/1/30 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 1/30/2012 4:20 PM, Stephen Woodbridge wrote:
>> The turn restrictions are handled differently in TRSP. You need to have
>> a table like:
>> target_edge_id (int4), to_cost(float8), via_path (text)
>> This is a replacement for the rule and at the moment
>> via_path := reverse(rule)
>> so if your rule = 1,2,3,4 then via_path = 4,3,2,1
>> I think that this will eventually change to be consistent with
>> shooting_star and the rule.
>> I believe that the way to interpret this is to apply the to_cost if the
>> current edge it target_edge_id and prior edge was 4, and 3 before that,
>> and 2 before that, and 1 before that. So the cost would NOT be applied
>> given this rule if the path was current_edge, 4, 3, 7 for example.
>> You may have multiple rules for a given target_edge_id.
> In my database, I have a table like this:
> CREATE TABLE trsp_rest
>  to_cost double precision,
>  target_id integer,
>  via_path text,
>  the_geom geometry,
>  "rule" text,
>  CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
>  CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'LINESTRING'::text OR the_geom IS NULL),
>  CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
> WITH (
>  OIDS=FALSE
> the geometry is just a copy of the target_id geometry that I can use to
> spatially restrict the restrictions to that of my query, but it is not
> required. You could also use a join to do the same thing.
> And then for the turn_restrict_sql you can pass something like:
> 'select to_cost, target_id, via_path from trsp_rest'
>  where the_geom && <bbox of query>'
> -Steve
>  -Steve
>> On 1/30/2012 4:00 PM, Jorge Eliécer Osorio Caro wrote:
>>> Hi Steve,
>>> I compile that version but i dont know very well the params that i need
>>> to send to:
>>> now we have via_path, means that edges where i can have access? its in
>>> replacement of rule?
>>> now we have that parameter to:
>>> sql text,
>>> source_id integer,
>>> target_id integer,
>>> directed boolean,
>>> has_reverse_cost boolean,
>>> turn_restrict_sql text)
>>> turn_restrict_sql what i need to pass there?
>>> i have something like this:
>>> SELECT * FROM turn_restrict_shortest_path( 'SELECT
>>> routing.network.segment as id, routing.network.source,
>>> routing.network.target, routing.network.length as cost,
>>> routing.network.reverse_length as reverse_cost, routing.network.x1,
>>> routing.network.y1, routing.network.x2, routing.network.y2,
>>> routing.network.rule as via_path, routing.network.to_cost FROM
>>> routing.network', -- node_from, node_to 15365, 15366, --15242, false, --
>>> directed true, -- reverse_cost 'ż?' )
>>> thanks steve.
>>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>
>>> Jorge,
>>> I have posted a few times on this problem, you can check the
>>> archives. The short story is the shooting star is broken. I think
>>> the last version that worked is 1.03. In my posts is also some
>>> information on a new algorithm turn_restricted_shortest_path (trsp)
>>> that is in a branch. The current code in a git branch works but is
>>> likely to see changes before it is released, but we do not have a
>>> release plan yet.
>>> -Steve
>>> On 1/30/2012 2:30 PM, Jorge Eliécer Osorio Caro wrote:
>>> Im having a issue when try to calculate the shortest path using turn
>>> restricctions this functions ignores the reverse_cost param.
>>> here the SQL:
>>> |SELECT
>>> FROM
>>> shortest_path_shooting_star(
>>> 'SELECT
>>> routing.network.x1,
>>> routing.network.y1,
>>> routing.network.x2,
>>> routing.network.y2,
>>> routing.network.rule,
>>> FROM
>>> routing.network',
>>> 15365,
>>> 15366,
>>> --15242,
>>> false, -- directed
>>> true-- reverse_cost
>>> this generate that route:
>>> http://cl.ly/ 242E2T0A2C410F1S0F3g
>>> <http://cl.ly/**242E2T0A2C410F1S0F3g <http://cl.ly/242E2T0A2C410F1S0F3g>
>>> that method generate the route but it ignores the one_way
>>> restriction ,
>>> the restriction is ok, but take a route where ignores that.
>>> now in the next image i need the marked red lines are the
>>> correct route
>>> because the 15229 and 15228 has both ways.
>>> http://cl.ly/ 3t2O38343F0F0C0o3P2c
>>> <http://cl.ly/**3t2O38343F0F0C0o3P2c <http://cl.ly/3t2O38343F0F0C0o3P2c>
>>> here how look my table:
>>> id source target cost reverse:cost rule to_cost x1, y1, x2, y2
>>> 15245 9082 9150 0.02 100.00021 15214 101.00021 -74.79981 10.94605
>>> -74.7996 10.94605
>>> how i cant fix that i compiled the last version of pgrouting
>>> from git repo.
>>> ______________________________ _________________
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo. org
>>> <mailto:Pgrouting-users at lists.**osgeo.org<Pgrouting-users at lists.osgeo.org>
>>> http://lists.osgeo.org/ mailman/listinfo/pgrouting- users
>>> <http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>> ______________________________**_________________
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120130/1e65ae04/attachment.html
More information about the Pgrouting-users mailing list
