[pgrouting-users] Which method to use?
Dave Potts dave.potts at pinan.co.uk
Tue Jan 31 06:53:15 EST 2012
Many Thanks Steve, much clearer,
The Google Summer of code solutions, do they work ?
I am trying to work out how to use the Driving Distance version, the one
documented at http://www.pgrouting.org/docs/1.x/dd.html
I am confused as to what the distance function should be set up, but the page
http://underdark.wordpress.com/2011/05/13/catchment-areas-with-pgrouting-driving_distance/
Is very helpful which describes this value as
'the only new value is “distance”. That’s the maximum distance/cost you
want to be contained in the result set. “distance” has to be specified in
the same units as the cost attribute (which is specified in the “sql” text
parameter).'
Dave.
Stephen Woodbridge wrote:
> On 1/30/2012 5:26 PM, Dave Potts wrote:
>> Is there a generic introduction which list what each of the route method
>> does and why I would what to use it with a given data set/
> There is a tutorial
>      http://www.pgrouting.org/docs/foss4g2008/index.html
> and here is my assessment:
> Dijkstra solution:
> This is a node based solution that converts a graph into a tree and the
> tree has all nodes that are reachable from the start node. This is used
> in the driving distance solution and has other applications where you
> might want the cost to get to multiple node. The default output is to
> only return that path from the start node to the destination node.
> Astar search solution:
> This is a modified Dijkstra solver that uses a Heuristic to direct the
> solver to the destination node. As a result, the graph solution is
> typically faster the Dijkstra because you only have to solve part of the
> graph needed to find the solution.
> ShootingStar solution:
> This is an edge based solver. IT IS CURRENT BROKEN! and as best as I can
> tell the last version that worked is v1.03. It is current running
> significantly (2-4x slower than the above two solutions). The reason it
> was created was because it support turn restrictions.
> These are the main three solvers.
> We just added a new branch TRSP (turn restricted shortest pat
More information about the Pgrouting-users mailing list
