[pgrouting-users] postgis 2.0 and postgresql 9.1
Sanak geosanak at gmail.com
Mon Jun 4 19:40:25 PDT 2012
Hi Ricardo,
I don't know all of the windows binaries, but I have not build 64bit
one yet.
PostGIS team have already supported windows mingw-64bit build,
http://postgis.refractions.net/pipermail/postgis-users/2012-April/033745.html
http://www.postgis.org/download/windows/#postgis-installers
and began to make more crossplatform build system.(I guess this means move
to cmake/msvc in windows).
http://blog.opengeo.org/2012/05/17/postgis-code-sprint-recap/
So, if the demand for windows 64bit binary seems to be large,
I will begin to investigate about it on my git(
https://github.com/sanak/pgrouting)
mingw/msvc branch.
Regards,
2012/6/4 Ricardo Bayley <ricardo.bayley at gmail.com>
> Is there a build for postgis under windows in a  64bit enviroment ?
> thanks
> 2012/5/23 Pedro Costa <pedrocostaarma at sapo.pt>
>> Hello James,
>> Of course. I have win7 64 bits with postgresql 9.1.2 and postgis 1.5.3.
>> I'm only copy the binaries [1] to the C path.
>> Now I will try with postgis 2.0 and return the results.
>> Thanks
>> [1] https://github.com/sanak/**pgrouting/downloads<https://github.com/sanak/pgrouting/downloads>
>> Em 23-05-2012 11:18, James David Smith escreveu:
>>  Hi Pedro,
>>> Would be very grateful if you'd provide a short summary of what you
>>> did to get it all working - along with links to the download packages?
>>> Thanks
>>> James
>>> On 23 May 2012 11:13, Pedro Costa<pedrocostaarma at sapo.pt>  wrote:
>>>> Perfect....works....
>>>> Thanks
>>>> Em 22-05-2012 23:42, Sanak escreveu:
>>>> Hi Pedro,
>>>> If you use pgRouting on Windows, download module from
>>>> here(https://github.com/sanak/**pgrouting/downloads<https://github.com/sanak/pgrouting/downloads>-
>>>> pgRouting-git-sanak-mingw_**20120310_pg-9.1(x86).zip).
>>>> Because above module was based on git master
>>>> branch(https://github.com/**pgRouting/pgrouting<https://github.com/pgRouting/pgrouting>)
>>>> after justjkk's latest
>>>> commit(2011/08/08), some drnextgis's sql fixes had already applied after
>>>> release 1.0.5,
>>>> but more drnextgis's fix(https://github.com/**
>>>> pgRouting/pgrouting/pull/50<https://github.com/pgRouting/pgrouting/pull/50>)
>>>> may
>>>> be necessary.
>>>> Hi Jorge,
>>>> Thanks for your report about PostgreSQL version incompatibility.
>>>> I will check about this problem.
>>>> Sorry for my english.
>>>> Regards,
>>>> 2012/5/23 Jorge Fuentes<jfuentes at estudiantes.**uci.cu<jfuentes at estudiantes.uci.cu>
>>>>> Was just easy like double clik and next next...
>>>>> but a had to download binaries from (I don't remember)
>>>>> .. but I'm sure that you will find that url in older post or googlering
>>>>> it..
>>>>> and be sure that you had postgreSQL 9.1.3 32 bit because i try with
>>>>> 9.1.1
>>>>> and not work because a dll change from that version to 9.1.3
>>>>> remember to execute .slq file from pgrouting
>>>>> best regards
>>>>> El 22/05/2012 12:35 pm, Pedro Costa escribió:
>>>>>> Em 22-05-2012 16:48, Jorge Fuentes escreveu:
>>>>>>> Yes I had them install and running PosgreSQL 9.1.3, postGIS 2.0 and
>>>>>>> pgrouting on win 7-32bits
>>>>>> Hi Jorge,
>>>>>> It was necessary to any change in code? Or were the normal procedures?
>>>>>> Thanks
>>>>>> ______________________________**_________________
>>>>>> Pgrouting-users mailing list
>>>>>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>>>>>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
>>>>>> 10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>>>>>> INFORMATICAS...
>>>>>> CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>>>>>> http://www.uci.cu
>>>>>> http://www.facebook.com/**universidad.uci<http://www.facebook.com/universidad.uci>
>>>>>> http://www.flickr.com/photos/**universidad_uci<http://www.flickr.com/photos/universidad_uci>
>>>>> INFORMATICAS...
>>>>> http://www.uci.cu
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120605/52e425f4/attachment.html>
More information about the Pgrouting-users mailing list
