[pgrouting-users] postgis 2.0 and postgresql 9.1
Pedro Costa pedrocostaarma at sapo.pt
Wed Jun 6 13:41:02 PDT 2012
Hi Daniel,
I don't know how to fix that but if anybody have an idea i can spent
some time trying...
any tips on how to solve the problem?
I created a new ticket:
https://github.com/pgRouting/pgrouting/issues/58
thanks
Em 06-06-2012 20:19, Daniel Kastl escreveu:
> Hi Pedro,
> If you were able to fix assign_vertex_id function for PostGIS 2.0,
> adding a ticket to the GitHub issue tracker [1] would be nice ... and
> even better with some patch.
> Daniel
> [1] https://github.com/pgrouting/pgrouting/issues?state=open
> On Wed, Jun 6, 2012 at 8:00 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     On 6/6/2012 12:53 PM, Pedro Costa wrote:
>         I'm trying now with postgis 2.0 and successfully create the
>         templatefor
>         routing based on postgis template 2.0.
>         The problem I found is the function assign_vertex that gives the
>         following error:
>         NOTICE: CREATE TABLE will create implicit sequence
>         "vertices_tmp_id_seq"
>         for serial column "vertices_tmp.id <http://vertices_tmp.id>"
>         CONTEXT: SQL statement "CREATE TABLE vertices_tmp (id serial)"
>         PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
>         ERROR: find_srid() - couldnt find the corresponding SRID - is the
>         geometry registered in the GEOMETRY_COLUMNS table? Is there an
>         uppercase/lowercase missmatch?
>         In postgis 2.0 we do not have table geometry_columns, anybody
>         know how
>         to solve this problem?
>     select Populate_Geometry_Columns();
>     should fix this.
>     -Steve
>         Thanks
>         Pedro
>         Em 05-06-2012 03:40, Sanak escreveu:
>             Hi Ricardo,
>             I don't know all of the windows binaries, but I have not
>             build 64bit
>             one yet.
>             PostGIS team have already supported windows mingw-64bit build,
>             http://postgis.refractions.net/pipermail/postgis-users/2012-April/033745.html
>             http://www.postgis.org/download/windows/#postgis-installers
>             and began to make more crossplatform build system.(I guess
>             this means
>             move to cmake/msvc in windows).
>             http://blog.opengeo.org/2012/05/17/postgis-code-sprint-recap/
>             So, if the demand for windows 64bit binary seems to be large,
>             I will begin to investigate about it on my
>             git(https://github.com/sanak/pgrouting)
>             mingw/msvc branch.
>             Regards,
>             2012/6/4 Ricardo Bayley <ricardo.bayley at gmail.com
>             <mailto:ricardo.bayley at gmail.com>
>             <mailto:ricardo.bayley at gmail.com>>>
>                Is there a build for postgis under windows in a 64bit
>             enviroment ?
>                thanks
>                2012/5/23 Pedro Costa <pedrocostaarma at sapo.pt
>             <mailto:pedrocostaarma at sapo.pt>
>             <mailto:pedrocostaarma at sapo.pt>>>
>                    Hello James,
>                    Of course. I have win7 64 bits with postgresql
>             9.1.2 and
>                    postgis 1.5.3. I'm only copy the binaries [1] to
>             the C path.
>                    Now I will try with postgis 2.0 and return the results.
>                    Thanks
>                    [1] https://github.com/sanak/pgrouting/downloads
>                    Em 23-05-2012 11:18, James David Smith escreveu:
>                        Hi Pedro,
>                        Would be very grateful if you'd provide a short
>             summary of
>                        what you
>                        did to get it all working - along with links to the
>                        download packages?
>                        Thanks
>                        James
>                        On 23 May 2012 11:13, Pedro
>             Costa<pedrocostaarma at sapo.pt <mailto:pedrocostaarma at sapo.pt>
>             <mailto:pedrocostaarma at sapo.pt>>> wrote:
>                            Perfect....works....
>                            Thanks
>                            Em 22-05-2012 23:42, Sanak escreveu:
>                            Hi Pedro,
>                            If you use pgRouting on Windows, download
>             module from
>              here(https://github.com/sanak/pgrouting/downloads -
>              pgRouting-git-sanak-mingw_20120310_pg-9.1(x86).zip).
>                            Because above module was based on git master
>              branch(https://github.com/pgRouting/pgrouting) after
>                            justjkk's latest
>                            commit(2011/08/08), some drnextgis's sql
>             fixes had
>                            already applied after
>                            release 1.0.5,
>                            but more drnextgis's
>              fix(https://github.com/pgRouting/pgrouting/pull/50) may
>                            be necessary.
>                            Hi Jorge,
>                            Thanks for your report about PostgreSQL version
>                            incompatibility.
>                            I will check about this problem.
>                            Sorry for my english.
>                            Regards,
>                            2012/5/23 Jorge
>             Fuentes<jfuentes at estudiantes.uci.cu
>             <mailto:jfuentes at estudiantes.uci.cu>
>             <mailto:jfuentes at estudiantes.uci.cu>>>
>                                Was just easy like double clik and next
>             next...
>                                but a had to download binaries from (I
>             don't remember)
>                                .. but I'm sure that you will find that
>             url in
>                                older post or googlering
>                                it..
>                                and be sure that you had postgreSQL
>             9.1.3 32 bit
>                                because i try with 9.1.1
>                                and not work because a dll change from that
>                                version to 9.1.3
>                                remember to execute .slq file from
>             pgrouting
>                                best regards
>                                El 22/05/2012 12:35 pm, Pedro Costa
>             escribió:
>                                    Em 22-05-2012 16:48, Jorge Fuentes
>             escreveu:
>                                        Yes I had them install and running
>                                        PosgreSQL 9.1.3, postGIS 2.0 and
>                                        pgrouting on win 7-32bits
>                                    Hi Jorge,
>                                    It was necessary to any change in
>             code? Or
>                                    were the normal procedures?
>                                    Thanks
>              _______________________________________________
>                                    Pgrouting-users mailing list
>             Pgrouting-users at lists.osgeo.org
>             <mailto:Pgrouting-users at lists.osgeo.org>
>             <mailto:Pgrouting-users at lists.osgeo.org>>
>             http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>                                    10mo. ANIVERSARIO DE LA CREACION DE LA
>                                    UNIVERSIDAD DE LAS CIENCIAS
>                                    INFORMATICAS...
>                                    CONECTADOS AL FUTURO, CONECTADOS A
>             LA REVOLUCION
>             http://www.uci.cu
>             http://www.facebook.com/universidad.uci
>             http://www.flickr.com/photos/universidad_uci
>             UNIVERSIDAD
>                                DE LAS CIENCIAS
>                                INFORMATICAS...
>                                CONECTADOS AL FUTURO, CONECTADOS A LA
>             REVOLUCION
>             http://www.uci.cu
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120606/795dc066/attachment-0001.html>
More information about the Pgrouting-users mailing list
