[pgrouting-users] Error in "dijkstra_sp_delta_directed" line 83
    Mathias Villeger
    mathias.villeger at gmail.com
    Thu Jun 21 02:25:35 PDT 2012
Hi Daniel,
I added type casts to request parameters but the error persists :
SELECT gid, the_geom FROM dijkstra_sp_delta( CAST( 'routes' AS varchar ),
CAST( :source AS int4 ), CAST( :target AS int4 ), CAST( :delta AS float8 )
I solved it changing this bloc of function dijkstra_sp_delta_directed :
*FOR rec IN EXECUTE 'SELECT CASE WHEN '||source_x||'<'||target_x||
           ' THEN '||source_x||' ELSE '||target_x||
           ' END as ll_x, CASE WHEN '||source_x||'>'||target_x||
           ' THEN '||source_x||' ELSE '||target_x||' END as ur_x'
        LOOP
END LOOP;
ll_x := rec.ll_x;
ur_x := rec.ur_x;
FOR rec IN EXECUTE 'SELECT CASE WHEN '||source_y||'<'||
            target_y||' THEN '||source_y||' ELSE '||
            target_y||' END as ll_y, CASE WHEN '||
            source_y||'>'||target_y||' THEN '||
            source_y||' ELSE '||target_y||' END as ur_y'
        LOOP
END LOOP;*
with bloc :
*    # Cast in Float to prevent plan error in PostgreSQL
    FOR rec IN EXECUTE 'SELECT CASE WHEN CAST('||source_x||' as float8)<
CAST('||target_x||
           ' as float8) THEN CAST('||source_x||' as float8) ELSE
CAST('||target_x||
           ' as float8) END as ll_x, CASE WHEN CAST('||source_x||' as
float8)>CAST('||target_x||
CAST('||target_x||' as float8) END as ur_x'
        LOOP
    END LOOP;
    ll_x := rec.ll_x;
    ur_x := rec.ur_x;
    FOR rec IN EXECUTE 'SELECT CASE WHEN CAST('||source_y||' as
float8)<CAST('||
            target_y||' as float8) THEN CAST('||source_y||' as float8) ELSE
CAST('||
            target_y||' as float8) END as ll_y, CASE WHEN CAST('||
            source_y||' as float8)>CAST('||target_y||' as float8) THEN
CAST('||
            source_y||' as float8) ELSE CAST('||target_y||' as float8) END
as ur_y'
        LOOP
    END LOOP;*
The error occured when source_x has not any decimal.
Should I create an issue on issue tracker?
Mathias.
2012/6/21 Daniel Kastl <daniel at georepublic.de>
> Hi Mathias,
> Could you post the query?
> The pgRouting function you're using is this one:
> https://github.com/pgRouting/pgrouting/blob/master/core/sql/routing_core_wrappers.sql#L594
> Can you check if the expected parameters have the right data types?
> If the data type is not correct it sometimes is enough to type cast.
> Daniel
> On Thu, Jun 21, 2012 at 9:57 AM, Mathias Villeger <
> mathias.villeger at gmail.com> wrote:
>> Hello,
>> I get the following error using the dijkstra_sp_delta function :
>> type of parameter 33 (integer) does not match that when preparing the
>> plan (numeric)
>>   Où : PL/pgSQL function "dijkstra_sp_delta_directed" line 83 at
>> assignment
>> PL/pgSQL function "dijkstra_sp_delta" line 19 at FOR over EXECUTE
>> statement
>> I didn't find anything about that.
>> I'm using postgis with a java application. Calls are done with
>> Hibernate's named queries, but I don't think that the use of Hibernate is
>> the cause of this error.
>> The error occurs randomly : A failing request can work at its next call.
>> Versions :
>> Postgres 9.1
>> Postgis 1.5
>> Pgrouting 1.0.5
>> Any idea about this?
>> Regards,
>> Mathias.
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120621/ccb655ef/attachment.html>
More information about the Pgrouting-users
