[pgrouting-users] pgrouting win7 postgreSQL 9.1 installation problem!!!
Jorge Fuentes jfuentes at estudiantes.uci.cu
Tue May 1 23:10:12 EDT 2012
Thank a lot just a few hours ago i had find those binary that you tell
me from Sanak GitHub, and i successful install
it.
Thank again..!!
El 01/05/2012 11:05 pm, Daniel Kastl escribió:
> Hi Jorge,
> No, I think it matters which version of PostgreSQL/PostGIS the Windows
> binaries were built.
> You can find binaries in the GitHub repository of Sanak:
> https://github.com/sanak/pgrouting/downloads
> Daniel
> On Wed, May 2, 2012 at 3:24 AM, Jorge Fuentes
> <jfuentes at estudiantes.uci.cu <mailto:jfuentes at estudiantes.uci.cu>> wrote:
>     Hi i just read the message below, and i understood that there is
>     not importance about what version of
>     PostgreSQL you were running you could use those binaries.. but i
>     try with 9.1 and i get an error
>     saying that i should use Postgres 8.4 then i don't
>     understand..(when i try to run .sql files in
>     /share/contrib/ folder)
>     I will appreciate any help
>     Hi James,
>     I am sorry to a late reply your mail because I become busy with my
>     writing
>     PhD Journal Paper.
>     About this
>     page:http://www.pgrouting.org/docs/howto/build_on_windows.html
>     you don't need to follow.
>     You can follow this steps;
>     Unzip a  ZIP file which you have downloaded (
>     "pgRouting-1.03_pg-8.4.2 ").
>     after you are unzip you will get 3 folders (Doc, Lib, and Share)
>     and if you
>     go to
>     "C:\Program Files (x86)\PostgreSQL\9.0" then you should see the
>     same name
>     folder as the folder when you unzip from pgRouting-1.03_pg-8.4.2.zip.
>     "C:\Program Files (x86)\PostgreSQL\9.0\Doc"
>     "C:\Program Files (x86)\PostgreSQL\9.0\lib"
>     "C:\Program Files (x86)\PostgreSQL\9.0\Share"
>     Then, copy all the data in the folder when you unzip from
>     pgRouting-1.03_pg-8.4.2.zip. and paste into the same folder name in
>     "C:\Program Files (x86)\PostgreSQL\9.0\...."
>     For example;
>     in "C:\Users\sittichai\Downloads\pgRouting-1.03_pg-8.4.2\Lib"
>     folder, copy
>     all 3 files (librouting.dll, libroutind_dd.dll,
>     librouting_tsp.dll) and
>     paste into "C:\Program Files (x86)\PostgreSQL\9.0\lib"
>     Please feel free to contract this mailing list if you have any
>     questions.
>     Sittichai
>     10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>     INFORMATICAS...
>     CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>     http://www.uci.cu
>     http://www.facebook.com/universidad.uci
>     http://www.flickr.com/photos/universidad_uci
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS INFORMATICAS...
http://www.uci.cu
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20120501/8035e85b/attachment.html
More information about the Pgrouting-users mailing list
