[pgrouting-users] postgis 2.0 and postgresql 9.1
Pedro Costa pedrocostaarma at sapo.pt
Wed May 23 06:30:26 EDT 2012
Hello James,
Of course. I have win7 64 bits with postgresql 9.1.2 and postgis 1.5.3.
I'm only copy the binaries [1] to the C path.
Now I will try with postgis 2.0 and return the results.
Thanks
[1] https://github.com/sanak/pgrouting/downloads
Em 23-05-2012 11:18, James David Smith escreveu:
> Hi Pedro,
> Would be very grateful if you'd provide a short summary of what you
> did to get it all working - along with links to the download packages?
> Thanks
> James
> On 23 May 2012 11:13, Pedro Costa<pedrocostaarma at sapo.pt>  wrote:
>> Perfect....works....
>> Thanks
>> Em 22-05-2012 23:42, Sanak escreveu:
>> Hi Pedro,
>> If you use pgRouting on Windows, download module from
>> here(https://github.com/sanak/pgrouting/downloads -
>> pgRouting-git-sanak-mingw_20120310_pg-9.1(x86).zip).
>> Because above module was based on git master
>> branch(https://github.com/pgRouting/pgrouting) after justjkk's latest
>> commit(2011/08/08), some drnextgis's sql fixes had already applied after
>> release 1.0.5,
>> but more drnextgis's fix(https://github.com/pgRouting/pgrouting/pull/50) may
>> be necessary.
>> Hi Jorge,
>> Thanks for your report about PostgreSQL version incompatibility.
>> I will check about this problem.
>> Sorry for my english.
>> Regards,
>> 2012/5/23 Jorge Fuentes<jfuentes at estudiantes.uci.cu>
>>> Was just easy like double clik and next next...
>>> but a had to download binaries from (I don't remember)
>>> .. but I'm sure that you will find that url in older post or googlering
>>> it..
>>> and be sure that you had postgreSQL 9.1.3 32 bit because i try with 9.1.1
>>> and not work because a dll change from that version to 9.1.3
>>> remember to execute .slq file from pgrouting
>>> best regards
>>> El 22/05/2012 12:35 pm, Pedro Costa escribió:
>>>> Em 22-05-2012 16:48, Jorge Fuentes escreveu:
>>>>> Yes I had them install and running PosgreSQL 9.1.3, postGIS 2.0 and
>>>>> pgrouting on win 7-32bits
>>>> Hi Jorge,
>>>> It was necessary to any change in code? Or were the normal procedures?
>>>> Thanks
>>>> _______________________________________________
>>>> Pgrouting-users mailing list
>>>> Pgrouting-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>>> 10mo. ANIVERSARIO DE LA CREACION DE LA UNIVERSIDAD DE LAS CIENCIAS
>>>> INFORMATICAS...
>>>> CONECTADOS AL FUTURO, CONECTADOS A LA REVOLUCION
>>>> http://www.uci.cu
>>>> http://www.facebook.com/universidad.uci
>>>> http://www.flickr.com/photos/universidad_uci
>>> INFORMATICAS...
>>> http://www.uci.cu
More information about the Pgrouting-users mailing list
