[pgrouting-users] osm2pgrouting oneway misreading
Sylvain Housseman hsylvio at gmail.com
Tue Oct 2 03:41:38 PDT 2012
Thank you, Tao!
I started changing the code as described below.
I added outputs, and "oneway" key contains many values corresponding to
the various versions of osm specs, such as:
Edge 140678882 has oneway entry with value yes
Edge 140678886 has oneway entry with value no
Edge 140678888 has oneway entry with value -1
Edge 140503091 has oneway entry with value true
but there also are aberrations such as
Edge 138507974 has oneway entry with value Bing which I will consider as
a "no"
I am downloading a most recent version of this .osm for testings and
I'll make osm2pgrouting work (more) properly (except if someone already
made the job; plz tell it!)
Thanks again for the answer Tao, but even if osm2pgrouting is far from
optimized I want to believe in open-source...
See you soon on GitHub then...
Le 02/10/2012 09:34, Tao Romera Martinez a écrit :
> Hi Sylvain,
> I think I was not able to import data using osm2pgrouting, so I
> instead used osm2po.
> Here is the memo I made for myself on how to use it:
> IMPORTING DATA FROM OSM INTO THE DATABASE
> 1. Download osm2po from http://osm2po.de/download.php?lnk=osm2po-4.4.4a.zip
> 2. Install in for example /usr/share/osm2po:
> sudo unzip /home/tao/Downloads/osm2po-4.4.4a.zip
> 3. Download osm file
> 4. Copy file to your osm2po folder:
> sudo cp /home/tao/Downloads/map.osm ./
> 4. Convert OSM file to DB file:
> sudo java -jar osm2po-core-4.4.4a-signed.jar prefix=at <file>.osm
> 5. Import DB file into database (username = postgres):
> psql -U postgres -d <your_DB> -q -f "/usr/share/osm2po/at/at_2po_4pgr.sql"
> Good luck,
> Tao
> 2012/10/2 Sylvain Housseman <hsylvio at gmail.com>:
>> Dear all,
>> I think that something is wrong with osm2pgrouting:
>> The code (Export2DB.cpp, called by osm2pgrouting.cpp) writes :
>>          if(way->oneway)
>>              row_data += TO_STR(way->length*1000000);
>>          else
>>              row_data += TO_STR(way->length);
>> (this row_data will be the reverse_cost value)
>> but after exporting france.osm I unfortunately observe that this condition
>> never seems to be met:
>>   franceRouting=> select count (*) from ways where reverse_cost <> length;
>>   count
>>        0
>>   (1 row)
>> So I guess that the condition (way->oneway) is not appropriated...
>> Does any version deal with this problem (or did I forget something when
>> launching osm2pgrouting)?
>> Thanks again for these great tools;
>> HSylvio.
>> BTW, the osm wiki page (http://wiki.openstreetmap.org/wiki/Key:oneway)
>> explains that
>> "Some tags (such as junction=roundabout, highway=motorway and others) imply
>> oneway=yes. You don't need to add a oneway tag
>> Values
>> oneway=yes (discouraged alternative: "true", "1")
>> oneway=no (discouraged alternative: "false", "0")
>> oneway=-1 (discouraged alternative: "reverse")
>> I did not understand yet how the XMLParser works, but could the problem be
>> solved by changing the type of "bool oneway" to a string or char[?] in the
>> "Way" class?
>> Best,
>> HSylvio.
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
