[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Dave Potts dave.potts at pinan.co.uk
Thu Aug 1 02:11:44 PDT 2013
On 01/08/13 05:03, Stephen Woodbridge wrote:
hi Ian,
I am running this software on Ubunto 12.04
I had some initial build issues mainly sorted by upgrade bits and bobs.
I am running
cmake 2.8.11
gcc version 4.6.3
bootst version 1.4.8
postgis  POSTGIS="2.0.0 r9605" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0,
6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
The development version compiles out of the box.
I not suggesting that you upgrade to any of these versions, but its a
set up that works.
regards
Dave
> Ian,
> This looks like something involving the includes in your old version
> of gcc. I'm running gcc version 4.7.2 (Debian 4.7.2-5) which is very
> new, but I also was compiling with gcc version 4.3.2 (Debian
> 4.3.2-1.1) and had no problems with that.
> You might try adding to k_targets_boost_wrapper.cpp:
> #include <sstream>
> It might need to be explicitly included on your version.
> -Steve
> On 7/31/2013 4:26 PM, Ian Tangert wrote:
>> Thanks Steve,
>> I got alot farther with pgrouting 2.0 over 1.05 but the make && make
>> install stopped with the following error:
>> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp: In
>> function ‘std::string toString(T)’:
>> /sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:282:
>> error: invalid use of undefined type ‘struct std::stringstream’
>> /usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iosfwd:83:
>> error: declaration of ‘struct std::stringstream’
>> make[2]: ***
>> [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o]
>> Error 1
>> make[1]: *** [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/all] Error 2
>> make: *** [all] Error 2
>> a few things i did:
>> i had to change the following cgal reference in the CMakeCache.txt
>>    =/usr/local/cgal/3.6.1/lib/libCGAL.so
>> Also, my make was:
>>    make -DWITH_DD=ON -WITH_TSP=ON .
>>        configuring done, generating done, no errors
>> make && make install
>> targets for trsp, astar, and dijkstra were built, but I don't understand
>> what the     new error means
>> On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>     Hi Ian,
>>     What version of pgRouting are you trying to install?
>>     I strongly recommend us 2.0.0 which is in beta and far more stable
>>     than 1.05.
>>     git clone https://github.com/pgRouting/__pgrouting.git
>>     <https://github.com/pgRouting/pgrouting.git>
>>     cd pgrouting
>>     git checkout develop
>>     mkdir build
>>     cd build
>>     cmake  -DWITH_DD=ON ..
>>     make && sudo make install
>>     cd ..
>>     tools/test-runner.pl <http://test-runner.pl>
>>     Read this for more information:
>>     https://github.com/pgRouting/__pgrouting/tree/develop
>>     <https://github.com/pgRouting/pgrouting/tree/develop>
>>     -Steve
>>     On 7/31/2013 3:10 PM, Ian Tangert wrote:
>>         hello,
>>         when i run make i get the following errors
>>         make
>>         [  8%] Building C object
>>         extra/tsp/src/CMakeFiles/__routing_tsp.dir/tsp.o
>>         In file included from
>>         /usr/pgsql-9.1/include/server/__nodes/execnodes.h:17,
>>                            from
>>         /usr/pgsql-9.1/include/server/__executor/execdesc.h:18,
>>                            from
>>         /usr/pgsql-9.1/include/server/__executor/executor.h:17,
>>                            from
>>         /usr/pgsql-9.1/include/server/__funcapi.h:21,
>>                            from
>>         /sources/pgrouting/pgrouting/__extra/tsp/src/tsp.c:26:
>>         if i edit the the files listed in the error output above so
>> that the
>>         line that says #include "node/somefile.h" has the full path to
>>         the file
>>         to be included (/usr/pgsql-9.1/include/__server/node/somefile.h)
>>         then the
>>         make command no longer produces an error.  but any time there is
>>         a new
>>         file to be included i need to edit the first file to include the
>>         full
>>         path and on and on.  Is there something i am missing so that
>>         that the
>>         pgrouting make "knows" that everything can be found somewhere in
>>         /usr/pgsql-9.1/include?
>>         my CMakeCahce.txt file looks like this:
>> POSTGRESQL_INCLUDE_DIR:__FILEPATH=/usr/pgsql-9.1/__include
>>         I am trying to install this on CentOS 5.5 with a postgresql
>>         installation
>>         that came from 9.1.9-1PGDG.rhel5, postgis also successfully
>>         installed
>>         and extension created in database
>>         would it work if i just kept adding the full path in the include
>>         line in
>>         the *.h files, and if I did would that mess anything up for
>>         postgres in
>>         general?
>>         thanks for any advice
>>         ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output looks like this:
>>         Boost headers were found here: /usr/include
>>         Output directory for libraries is set to /usr/pgsql-9.1/lib
>>         Installation directory for libraries is set to
>>         /usr/pgsql-9.1/lib and
>>         for SQL files is set to /usr/share/pgrouting
>> /usr/pgsql-9.1/lib
>>         -- Configuring done
>>         -- Generating done
>>         -- Build files have been written to:
>>         _________________________________________________
>>         Pgrouting-users mailing list
>>         Pgrouting-users at lists.osgeo.__org
>>         <mailto:Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>> <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users mailing list
