[pgrouting-users] Validity of the pgrouting workshop
Daniel Kastl daniel at georepublic.de
Sat Jul 20 07:00:36 PDT 2013
On Sat, Jul 20, 2013 at 9:15 PM, Hishan Melanga <hishanm at gmail.com> wrote:
> Currently I was able to install and import osm data into a routing
> database. I can draw the shortes route using Quantum GIS using a query. But
> in the workshop website it tells us to create a server side script<http://workshop.pgrouting.org/chapters/php_server.html>.
> We do not have to create it since the workshop folder already has it. But
> it is not working when I try to run the browser client called
> routing-final.html file. Only the map is shown path is not drawn when I put
> two markers.
> I downloaded the pgrouting source from
> I downloaded the workshop from
> https://github.com/pgRouting/workshop
> I also noticed that there is a pgrouting-build and workshop-build folders
> in the git hub project. But this "workshop-build" does not contain the old
> php "server side script". Is this workshop-build is compatible with the old
> workshop or is this workshop-build only compatible with pgrouting-build?
> I just want to display the shortest path in the website. Please help me
> with this problem.
> හිෂාන් මෙලංග | Hishan Melanga <http://hishanmelanga.blogspot.com/>
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
The problem with the "old" current workshop is, that it is not working with
pgRouting 2.0 and probably not working with PostGIS 2.0
Though the workshop will be updated for FOSS4G 2013 in September. Then it
will not work anymore for pgRouting 1.05.
So right now it's probably confusing, but it's difficult to support both
versions at the same time.
Currently the priority is to release a stable version of 2.0, so the
workshop will not work for some people until September.
I'm sorry for that, but my personal time is limited. Contributions to fix
it are welcome. Or if you can provide some funding, then it can also be
done faster.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130720/2c8a7515/attachment.html>
More information about the Pgrouting-users mailing list
