[pgrouting-users] Running test sequeances
Dave Potts dave.potts at pinan.co.uk
Tue Jul 23 04:11:28 PDT 2013
On 23/07/13 12:46, sanak wrote:
Thanks Sanak, I think I known why the TSP fails, but I want to make
sure,  I would also like to test the TSP with a larger distance marix.
Dave.
> Hi Dave,
> You can see test-runner.pl <http://test-runner.pl> usage by executing
> following command.
> $ cd /path/to/pgrouting-root
> $ tools/test-runner.pl <http://test-runner.pl> -h
> RUNNING: test-runner.pl <http://test-runner.pl> -h
> Usage: test-runner.pl <http://test-runner.pl> -pgver vpg -pgisver
> vpgis -psql /path/to/psql
>        -pgver vpg          - postgresql version
>        -pgport port        - postgresql port to use (default: 5432)
>        -pgisver vpgis      - postgis version
>        -pgrver vpgr        - pgrouting version
>        -psql /path/to/psql - optional path to psql
>        -v                  - verbose messages for debuging(enter twice
> for more)
>        -clean              - dropdb pgr_test__db__test
>        -ignorenotice       - ignore NOTICE statements when reporting
> failures
>        -h                  - help
> And I use the following commands normally.
> $ which psql
> /path/to/psql
> $ tools/test-runner.pl <http://test-runner.pl> -psql /path/to/psql
> -ignorenotice
> * As Stephen mentioned, currently, tsp's last test fail.
> The test file specification is here.
> https://github.com/pgRouting/pgrouting/wiki/2.0-Development-Guidelines-and-Standards#test-standards
> Thanks,
> 2013/7/23 Dave Potts <dave.potts at pinan.co.uk
> <mailto:dave.potts at pinan.co.uk>>
>     hi
>     I am looking at a bug in part of the pgroute software,  I like to
>     be able to run the 'test software'
>     I found a perl script in pgrouting-develop/tools called
>     Is there any documentation on how to run it?
>     I noticed that most of the pgroute software has a test directory,
>     is there any information on how to add new a test case or the
>     format of a test case/
>     regards
>     Dave.
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Ko Nagase (sanak)
> Georepublic Japan
> mail: geosanak at gmail.com <mailto:geosanak at gmail.com>
> nagase at georepublic.co.jp <mailto:nagase at georepublic.co.jp>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130723/04590d87/attachment.html>
More information about the Pgrouting-users mailing list
