[pgrouting-users] Make pgrouting doesn't find postgres include dirs
Ian Tangert itangert at gmail.com
Wed Jul 31 13:26:00 PDT 2013
Thanks Steve,
I got alot farther with pgrouting 2.0 over 1.05 but the make && make
install stopped with the following error:
/sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp: In
function ‘std::string toString(T)’:
/sources/pgrouting/src/kdijkstra/src/k_targets_boost_wrapper.cpp:282:
error: invalid use of undefined type ‘struct std::stringstream’
/usr/lib/gcc/x86_64-redhat-linux/4.1.2/../../../../include/c++/4.1.2/iosfwd:83:
error: declaration of ‘struct std::stringstream’
make[2]: ***
[src/kdijkstra/src/CMakeFiles/kdijkstra.dir/k_targets_boost_wrapper.cpp.o]
Error 1
make[1]: *** [src/kdijkstra/src/CMakeFiles/kdijkstra.dir/all] Error 2
make: *** [all] Error 2
a few things i did:
i had to change the following cgal reference in the CMakeCache.txt
  =/usr/local/cgal/3.6.1/lib/libCGAL.so
Also, my make was:
  make -DWITH_DD=ON -WITH_TSP=ON .
      configuring done, generating done, no errors
make && make install
targets for trsp, astar, and dijkstra were built, but I don't understand
what the     new error means
On Wed, Jul 31, 2013 at 3:27 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Ian,
> What version of pgRouting are you trying to install?
> I strongly recommend us 2.0.0 which is in beta and far more stable than
> 1.05.
> git clone https://github.com/pgRouting/**pgrouting.git<https://github.com/pgRouting/pgrouting.git>
> cd pgrouting
> git checkout develop
> mkdir build
> cd build
> cmake  -DWITH_DD=ON ..
> make && sudo make install
> cd ..
> tools/test-runner.pl
> Read this for more information:
> https://github.com/pgRouting/**pgrouting/tree/develop<https://github.com/pgRouting/pgrouting/tree/develop>
> -Steve
> On 7/31/2013 3:10 PM, Ian Tangert wrote:
>> hello,
>> when i run make i get the following errors
>> make
>> [  8%] Building C object extra/tsp/src/CMakeFiles/**routing_tsp.dir/tsp.o
>> In file included from /usr/pgsql-9.1/include/server/**
>> nodes/execnodes.h:17,
>> executor/execdesc.h:18,
>> executor/executor.h:17,
>>                   from /usr/pgsql-9.1/include/server/**funcapi.h:21,
>>                   from /sources/pgrouting/pgrouting/**
>> extra/tsp/src/tsp.c:26:
>> if i edit the the files listed in the error output above so that the
>> line that says #include "node/somefile.h" has the full path to the file
>> to be included (/usr/pgsql-9.1/include/**server/node/somefile.h) then the
>> make command no longer produces an error.  but any time there is a new
>> file to be included i need to edit the first file to include the full
>> path and on and on.  Is there something i am missing so that that the
>> pgrouting make "knows" that everything can be found somewhere in
>> /usr/pgsql-9.1/include?
>> my CMakeCahce.txt file looks like this:
>>    POSTGRESQL_INCLUDE_DIR:**FILEPATH=/usr/pgsql-9.1/**include
>> I am trying to install this on CentOS 5.5 with a postgresql installation
>> that came from 9.1.9-1PGDG.rhel5, postgis also successfully installed
>> and extension created in database
>> would it work if i just kept adding the full path in the include line in
>> the *.h files, and if I did would that mess anything up for postgres in
>> general?
>> thanks for any advice
>> ps my cmake -DWITH_TSP=ON -DWITH_DD=ON . output looks like this:
>> Boost headers were found here: /usr/include
>> Output directory for libraries is set to /usr/pgsql-9.1/lib
>> Installation directory for libraries is set to /usr/pgsql-9.1/lib and
>> for SQL files is set to /usr/share/pgrouting
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /sources/pgrouting/pgrouting
>> ______________________________**_________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.**org <Pgrouting-users at lists.osgeo.org>
>> http://lists.osgeo.org/**mailman/listinfo/pgrouting-**users<http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130731/83283fdc/attachment.html>
More information about the Pgrouting-users mailing list
