[pgrouting-users] postgis 2.0 error find_srid()
Pedro Costa pedrocostaarma at sapo.pt
Fri Mar 15 05:17:13 PDT 2013
Hi Ian,
I don't have any function called 'st_find_srid'...
May be you changed another function?
Em 15-03-2013 12:01, Ian Tangert escreveu:
> hi,
> does it work if you change the find_srid() function to st_find_srid()
> in the assign_vertex_id function()? I had to add st_ to some of the
> functions inside the pgrouting functions once, but I'm sorry I can't
> remember now exactly how I built that platform,but it was postgis 2.0,
> Ian
> -------- Original message --------
> Subject: [pgrouting-users] postgis 2.0 error find_srid()
> From: Pedro Costa <pedrocostaarma at sapo.pt>
> To: pgRouting users mailing list <pgrouting-users at lists.osgeo.org>
> CC:
> Hi guys,
> I'm installed the pgrouting with postgres 9.1.8 and postgis 2 and i have
> all my data in a distint schema (not 'public')...
> When i run the query to create topology [1] i get an error [2].
> I'm already try to run select 'populate_geometry_columns()' and the
> table is corectly referenced in geometry_columns.
> Can anybody help me with that or a different function of postgis to
> create topology?
> thanks
> [1]
> SELECT assign_vertex_id('arcos', .001, 'the_geom', 'id');
> [2]
> NOTICE:  CREATE TABLE will create implicit sequence
> "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
> CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
> PL/pgSQL function "assign_vertex_id" line 15 at EXECUTE statement
> ERROR:  find_srid() - couldnt find the corresponding SRID - is the
> geometry registered in the GEOMETRY_COLUMNS table?  Is there an
> uppercase/lowercase missmatch?
> CONTEXT:  PL/pgSQL function "assign_vertex_id" line 21 at assignment
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130315/f624b888/attachment.html>
More information about the Pgrouting-users mailing list
