[pgrouting-users] sew-devel-2_0 build problems
Dave Potts dave.potts at pinan.co.uk
Sat May 25 02:11:20 PDT 2013
Hi list
I want a play from the new version of the tsp code.
I have tried building it on Ubuntu  3.2.0-43-generic #68-Ubuntu SMP with
postgres 9.1.9 using the syntax
cmake DebugFull .
I got the following errors[See Below]
Q. What should the build envronment be pgroute 2.0??
I have already upgraded my version of cmake 2.8.11
regards
Dave.
src/pgroute/pgr2.0/pgrouting-sew-devel-2_0 failed with output:
   fatal: Not a git repository (or any parent up to mount parent )
   Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not
set).
Call Stack (most recent call first):
   CMakeLists.txt:68 (GIT_WC_INFO)
CMake Warning at cmake/FindGit.cmake:144 (message):
   No remote origin set for git repository:
   /home/dp42/src/pgroute/pgr2.0/pgrouting-sew-devel-2_0
-- POSTGRESQL_EXECUTABLE is /usr/lib/postgresql/9.1/bin/postgres
-- POSTGRESQL_PG_CONFIG is /usr/bin/pg_config
-- POSTGRESQL_INCLUDE_DIR: /usr/include/postgresql/9.1/server
-- POSTGRESQL_LIBRARIES: /usr/lib
-- Boost version: 1.48.0
Boost headers were found here: /usr/include
-- POSTGRESQL_VERSION_STRING is PostgreSQL 9.1.9
-- POSTGRESQL_VERSION is 9.1.9
-- Install directory for libraries is set to /usr/lib/postgresql/9.1/lib
-- Install directory for SQL files is set to
/usr/share/postgresql/9.1/extension
-- LIBS_TO_INSTALL=
-- Configuring incomplete, errors occurred!
More information about the Pgrouting-users mailing list
