[pgrouting-users] PGRoting Workshop step 4.2 can't create vertices_tmp , vertices_tmp_id_seq
Daniel Kastl daniel at georepublic.de
Fri May 31 23:20:09 PDT 2013
On Sat, Jun 1, 2013 at 2:16 PM, Sithila Konara
<sithilamadushanka at gmail.com>wrote:
> I'm following pgrouing workshop. I followed steps as they said I executed
> the command
> osm2pgrouting -file "data/sampledata.osm" \
>                           -conf "/usr/share/osm2pgrouting/mapconfig.xml" \
>                           -dbname routing \
>                           -user postgres \
>                           -clean
> and check the database using
> psql -U postgres -d routing -c "\d"
> but create  vertices_tmp , vertices_tmp_id_seq tables not created...
> How do I do create this tables ?
They are created by osm2pgrouting.
When you run it, didn't it return any errors?
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130601/c4e47a3a/attachment.html>
More information about the Pgrouting-users mailing list
