[pgrouting-users] OSM2pgRouting failling silently
Daniel Kastl daniel at georepublic.de
Mon Sep 2 08:29:42 PDT 2013
On Tue, Sep 3, 2013 at 12:24 AM, Luís de Sousa <luis.a.de.sousa at gmail.com>wrote:
> Hi again Daniel,
> I think this only replaced one problem for another. I tried to recreate a
> routing database to import again the data but the /usr/share/postlbs folder
> no longer exists. Thinking that it might be missing due to packages lacking
> I tried to reinstalled them, but I get errors with both (see below). So now
> I have osm2pgrouting working but no pgrounting...
> Luís
Hi Luís,
You have installed the new pgRouting 2.0, which contains many changes and
there might be lot of outdated documentation now available in internet.
It probably helps to read the new documentation. It will answer most of
your questions: http://docs.pgrouting.org/
Daniel
> $ sudo apt-get install postgresql-9.1-pgrouting-tsp
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> The following NEW packages will be installed
> 0 upgraded, 1 newly installed, 0 to remove and 24 not upgraded.
> Need to get 0 B/12.0 kB of archives.
> After this operation, 76.8 kB of additional disk space will be used.
> (Reading database ... 486495 files and directories currently installed.)
> Unpacking postgresql-9.1-pgrouting-tsp (from
> .../postgresql-9.1-pgrouting-tsp_1.05-1~precise2_amd64.deb) ...
> dpkg: error processing
> /var/cache/apt/archives/postgresql-9.1-pgrouting-tsp_1.05-1~precise2_amd64.deb
> (--unpack):
>  trying to overwrite '/usr/lib/postgresql/9.1/lib/librouting_tsp.so', which
> is also in package postgresql-9.1-pgrouting 2.0.0-rc1-ppa20~precise1
> Errors were encountered while processing:
> E: Sub-process /usr/bin/dpkg returned an error code (1)
> $ sudo apt-get install postgresql-9.1-pgrouting-dd
> Need to get 0 B/69.6 kB of archives.
> After this operation, 253 kB of additional disk space will be used.
> Unpacking postgresql-9.1-pgrouting-dd (from
> .../postgresql-9.1-pgrouting-dd_1.05-1~precise2_amd64.deb) ...
> /var/cache/apt/archives/postgresql-9.1-pgrouting-dd_1.05-1~precise2_amd64.deb
> (--unpack):
>  trying to overwrite '/usr/lib/postgresql/9.1/lib/librouting_dd.so', which
> http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-OSM2pgRouting-failling-silently-tp4025288p4025299.html
> Sent from the pgRouting-users mailing list archive at Nabble.com.
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130903/94c947fa/attachment.html>
More information about the Pgrouting-users mailing list
