[pgrouting-users] postgres version for pgrouting?
Daniel Kastl daniel at georepublic.de
Fri Sep 27 15:03:29 PDT 2013
HI Worth,
The pgRouting versions in the PPA are always for the PostgreSQL version
that is default in Ubuntu.
And the default version is since 12.04 is PostgreSQL 9.1
It seems that the next version of Ubuntu will still have PostgreSQL 9.1, so
it's not going to change.
With Travis we test pgRouting also with other versions of PostgreSQL, so
9.2 should work.
https://github.com/pgRouting/pgrouting/blob/master/tools/travis/pgrouting_install.sh
But you have to compile yourself, because I'm not able to maintain this as
PPA in my spare time.
Daniel
On Sat, Sep 28, 2013 at 3:45 AM, Worth Lutz <wal3 at mindspring.com> wrote:
>  I assume you mean if it is built from source.****
> I usually load from the ppa:georepublic/pgrouting****
> I try to avoid building stuff myself unless absolutely necessary.****
> So I guess my question is: must I build from source or will other versions
> be available from the ppa?****
> Worth****
> *From:* pgrouting-users-bounces at lists.osgeo.org [mailto:
> pgrouting-users-bounces at lists.osgeo.org] *On Behalf Of *James David Smith
> *Sent:* Friday, September 27, 2013 2:37 PM
> *To:* pgRouting users mailing list
> *Subject:* Re: [pgrouting-users] postgres version for pgrouting?****
> It'll work fine with 9.2.****
> On 27 Sep 2013 19:31, "Worth Lutz" <wal3 at mindspring.com> wrote:****
> I’m running on Ubuntu and getting pgRouting from the ppa.****
> Is Postgresql v.9.1 the only version supported?****
> I believe that my clients are using 9.2.****
> Worth Lutz****
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users****
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2014.0.4142 / Virus Database: 3604/6700 - Release Date: 09/26/13*
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20130928/5453880b/attachment-0001.html>
More information about the Pgrouting-users mailing list
