[pgrouting-users] pgrouting Dijksta Travelling Salesman Problem (TSP) with OpenStreetmap
Stephen Woodbridge woodbri at swoodbridge.com
Tue Feb 25 12:23:29 PST 2014
I'm busy for the next few days so I will not have time to look at it
until later this week.
What version of postgresql are you running?
select * from version();
I would google "postgresql array functions" and read up on these.There
is a function that will tell you the dimensions of an array and maybe
you need to print out some more notices to figure out what it is expecting.
Maybe someone else on the list wants to take a crack at this.
Thanks,
   -Steve
On 2/25/2014 3:14 PM, Carsten Hogertz wrote:
> Hi Steve,
> have been busy the last days so I only check your Thursday's solution
> right now. Still not working.
> My function looks like this:
> create or replace function pgr_makeDijkstraMatrix(thetbl text, sqlP
> text, OUT dmatrix double precision[], OUT ids integer[])
>    as
> $body$
> declare
>      sql text;
>      sql2 text;
>      r record;
>      r2 record;
>      i integer;
>      j integer;
>      matrixl double precision[];
> begin
> ids := '{}'::integer[];
>      sql:='select node, id-1 as id from '||thetbl;
>      for r in execute sql loop
>              sql2:='select id1, array_agg(cost) as arow from (
>            SELECT id1, id2, cost
>            FROM pgr_kdijkstraCost('''||sqlP||''', '||r.node||
>                ', (select array_agg(node) from '||thetbl||' where
> id>'||r.id <http://r.id>||'), false, false)
>           ) as foo group by id1 order by id1';
>          for r2 in execute sql2 loop
>          matrixl := '{}';
>          for i in 1..r.id <http://r.id> loop
>                    matrixl := array_append(matrixl, dmatrix[i][r.id
> <http://r.id>+1]);
>                  end loop;
>                  matrixl := array_cat(matrixl, r2.arow);
>              dmatrix := array_cat(dmatrix, array[matrixl]);
> raise notice 'r2: %', r2;
> raise notice 'r2.id1: %', r2.id1;
> raise notice 'ids: %', ids;
>             --ids := ids || r2.id1;
> ids := array_cat(ids, array[r2.id1]);
>          end loop;
>      end loop;
> end;
> $body$
> language plpgsql stable cost 10;
> create or replace function pgr_tspDijkstra(thetbl text, sql text,
> start_id integer, end_id integer default (-1))
>      returns setof pgr_costResult as
> $body$
> declare
>      sid integer;
>      eid integer;
> begin
>      return query with dm  as (
>          select * from pgr_makeDijkstraMatrix( thetbl, sql )
>      ids as (
>          select (row_number() over (order by id asc))-1 as rnum, id
>            from (
>                  select unnest(ids) as id
>                    from dm
>                  ) foo
>      t as (
>          select a.seq, b.rnum, b.id <http://b.id>
>            from pgr_tsp(
>                     (select dmatrix from dm),
>                     (select rnum from ids where id=start_id limit
> 1)::integer,
>                     (case when end_id = -1 then -1 else (select rnum
> from ids where id=end_id limit 1) end)::integer
>                 ) a,
>                 ids b
>           where a.id <http://a.id>=b.rnum
>      r as (
>          select array_agg(t.rnum) as rnum from t
>      select t.seq::integer,
>             t.rnum::integer as id1,
>             t.id::integer as id2,
> dm.dmatrix[r.rnum[t.seq+1]+1][r.rnum[(t.seq+1)%array_length(r.rnum,
> 1)+1]+1]::float8 as cost
>        from t, dm, r;
> end;
> $body$
> language plpgsql volatile cost 50 rows 50;
> create or replace function pgr_tspDijkstraLen(thetbl text, start_id
> $body$
> begin
>       return query SELECT * FROM pgr_tspDijkstra(thetbl,
>            'SELECT  id, source::integer, target::integer, length::double
> precision AS cost FROM cgn_2po_4pgr',
>             start_id, end_id);
> end;
> $body$
> language plpgsql stable;
> AND the error I am getting:
> NOTICE:  r2:
> (34304,"{0,5.3602868897,4.6782573327,5.6026971537,5.2062747797,5.0497181017,5.3147719797,5.0700916462,4.3220066797,4.8593618137,4.0002255227,6.055760592,12.5155379824,9.3170226155,8.72783427270001,5.9460446587,3.0868131677,5.1839796057,5.2301666167,2.1211198847,5.7037465591,2.7282842677,8.4758437557,11.1027935904,7.9434273599,7.8361619299,7.7610621969,7.4929139614,5.8106133327,5.9579132527,5.9888473034,6.5618433959,4.5013708887,1.9218516244,5.7559805232,5.2267081177,5.0968196707,4.8949133597,5.9137964962,4.2936059427,4.6948533593,3.4377318427,3.7991617067,4.1242444467,3.8858731777,3.9596393887,4.9192685996,4.6734033563,4.7511846457,4.4544981945,4.2748693367,3.411559417,6.6851381985,6.6744741285,6.9296475385,7.0136847108,7.1371500908,7.2719520708,6.6787720528,7.3530295908,6.8599596928,7.2216891568,7.4951304208,7.4404728868,8.1332243958,6.2736028029,6.963685048,6.0483763169,5.8653351624,5.6164044005,6.54979166,5.8783224469,6.533468297,5.8553434082,5.7676662122,6.267915357,5.22607939
03,3.745459072,6.352470342,5.4392033722,5.5562602522,5.3996670482,6.171297855,5.648779598,5.5653279855,5.671668653,5.3243595462,5.879320328,5.859442385,6.080574272,5.3767159992,6.170852717,5.3001119472,5.687201287,5.3573110752,3.586385579,5.566591422,5.5104826925,5.916268775,5.4418422465,5.4037394705,5.640889612,5.1407657702,4.5523677017,5.3873769863,3.601570449,2.978252449,4.8725960282,4.9817842222,5.2355359365,5.1227105795,5.177856607,5.098596533,5.1891181988,4.9327118245,4.4632330777,7.4879538737,4.8591269625,3.1339054377,5.8472818275,4.6043306952,3.3542942377,4.7660145915,6.6679095357,5.51150886,2.7404344677,5.9332075344,6.2019594857,5.266709364,5.4924174224,5.180577724,3.0277711677,6.2913260157,4.2862670877,5.5461328154,5.5809644644,5.1132029296,5.1904326724,4.8352505633,4.9641930171,5.1366240426,7.0699378037,3.1274712477,5.1487646306,5.2717034197,5.0200090866,3.0911490977,5.8984613527,5.1973381747,4.2427530627,6.7293864957,4.7943011637,5.1130266607,5.3948779287,4.7124246547,5.2
186371577,2.9723417287,2.3171875277,2.8159853427,4.7913513947,4.7863347867,3.4531342837,3.8161332287,5.8431115757,4.4873126817,5.6577494097,5.5867970832,9.4583860946,2.7784615917,5.4279953797,1.9376872717,5.0813930177,5.8860618114,6.2411339874,6.4536904614,6.0972641874,5.7247963284,5.9823452114,5.8316140784,5.2398164977,6.2963392357,5.5864457124,6.1599995178,5.2609646384,6.1012355027,6.4129483756,6.0056487896,5.0106569884,5.4239402364,6.1148656496,2.673828844,4.3332873457,3.2943586634,4.5834393467,7.278601561,3.5870893269,3.3299191554,4.1049776549,5.9256568037,6.2719334873,6.2594329923,5.5752581689,5.6058592867,6.1311384893,6.4726413519,5.8973941434,6.2572672069,5.9667442136,5.3965422637,7.2837623985,6.9586195092,7.1137641952,6.3682104908,7.8495628418,7.2245886958,6.2983788278,7.3509762248,6.9925366658,6.5600944468,6.936328733,6.616665943,6.738732443}")
> CONTEXT:  PL/pgSQL function "pgr_tspdijkstra" line 8 at RETURN QUERY
> PL/pgSQL function "pgr_tspdijkstralen" line 3 at RETURN QUERY
> NOTICE:  r2.id1: 34304
> NOTICE:  ids: {}
> ERROR:  cannot concatenate incompatible arrays
> DETAIL:  Arrays with differing element dimensions are not compatible for
> concatenation.
> CONTEXT:  PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
> ********** Fehler **********
> SQL Status:2202E
> Detail:Arrays with differing element dimensions are not compatible for
> concatenation.
> Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 26 at assignment
> HOW comes? I really don't know what to do.
> May you be so kind and try to help again?
> Thanks
> Carsten
> 2014-02-21 9:36 GMT+01:00 Carsten Hogertz <carsten.hogertz at gmail.com
> <mailto:carsten.hogertz at gmail.com>>:
>     2014-02-20 23:25 GMT+01:00 Stephen Woodbridge
>     <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>:
>         On 2/20/2014 4:59 PM, Carsten Hogertz wrote:
>             2014-02-20 22:47 GMT+01:00 Stephen Woodbridge
>             <mailto:woodbri at swoodbridge.__com
>             <mailto:woodbri at swoodbridge.com>>>:
>                  On 2/20/2014 4:39 PM, Carsten Hogertz wrote:
>                      2014-02-20 22:20 GMT+01:00 Stephen Woodbridge
>             <mailto:woodbri at swoodbridge.>____com
>             <mailto:woodbri at swoodbridge.com>>>>:
>                           On 2/20/2014 3:54 PM, Carsten Hogertz wrote:
>                               Thanks Steve,
>                               coming home and adding your lines it
>             returns with an error:
>                               NOTICE:  r2:
>                               (34304,"{0,5.3602868897 <tel:3602868897>
>             <tel:3602868897 <tel:3602868897>>
>                      <tel:3602868897 <tel:3602868897> <tel:3602868897
>             <tel:3602868897>>>,4.6782573327 <tel:6782573327>
>             <tel:6782573327 <tel:6782573327>>
>             <tel:6782573327 <tel:6782573327>>>,5.6026971537 <tel:6026971537>
>                      <tel:6026971537 <tel:6026971537>> <tel:6026971537
>             <tel:6026971537> <tel:6026971537
>             <tel:6026971537>>>,5.2062747797 <tel:2062747797>
>                      <tel:2062747797 <tel:2062747797>>
>                      <tel:2062747797
>             <tel:2062747797>>>,5.__0497181017,5.3147719797
>             <tel:3147719797> <tel:3147719797 <tel:3147719797>>
>                      <tel:3147719797
>             <tel:3147719797>>>,5.__0700916462,4.____3220066797,4.__8593618137
>             <tel:8593618137>
>                      <tel:8593618137 <tel:8593618137>>
>                      <tel:8593618137
>             <tel:8593618137>>>,4.0002255227,6.______055760592,12.5155379824
>             <tel:5155379824>
>                      <tel:5155379824 <tel:5155379824>>
>                      <tel:5155379824
>             <tel:5155379824>>>,9.__3170226155,8.____72783427270001,5.__9460446587,____3.0868131677,5.__1839796057,__5.__2301666167,2.__1211198847,__5.__7037465591
>             <tel:7037465591>
>                      <tel:7037465591 <tel:7037465591>>
>                      <tel:7037465591
>             <tel:7037465591>>>,2.__7282842677,8.4758437557
>             <tel:4758437557> <tel:4758437557 <tel:4758437557>>
>                      <tel:4758437557
>             <tel:4758437557>>>,11.__1027935904,7.____9434273599,7.__8361619299,7.____7610621969,7.__4929139614,5.____8106133327
>             <tel:8106133327>
>                      <tel:8106133327 <tel:8106133327>>
>                      <tel:8106133327
>             <tel:8106133327>>>,5.__9579132527,5.____9888473034,6.__5618433959
>             <tel:5618433959>
>                      <tel:5618433959 <tel:5618433959>>
>             <tel:5618433959 <tel:5618433959>>>,4.5013708887 <tel:5013708887>
>                      <tel:5013708887 <tel:5013708887>>
>                      <tel:5013708887
>             <tel:5013708887>>>,1.__9218516244,5.____7559805232,5.__2267081177
>             <tel:2267081177>
>                      <tel:2267081177 <tel:2267081177>>
>                      <tel:2267081177
>             <tel:2267081177>>>,5.0968196707,4.______8949133597,5.9137964962
>             <tel:9137964962>
>                      <tel:9137964962 <tel:9137964962>>
>                      <tel:9137964962
>             <tel:9137964962>>>,4.__2936059427,4.____6948533593,3.__4377318427
>             <tel:4377318427>
>                      <tel:4377318427 <tel:4377318427>>
>                      <tel:4377318427
>             <tel:4377318427>>>,3.7991617067,4.______1242444467,3.8858731777,3.______9596393887,4.9192685996
>             <tel:9192685996>
>                      <tel:9192685996 <tel:9192685996>>
>                      <tel:9192685996
>             <tel:9192685996>>>,4.__6734033563,4.____7511846457,4.__4544981945,4.____2748693367,3.__411559417,6.____6851381985,6.__6744741285,6.____9296475385
>             <tel:9296475385>
>                      <tel:9296475385
>             <tel:9296475385>>,7.__0136847108,7.____1371500908,7.__2719520708,6.__6787720528
>             <tel:6787720528>
>                      <tel:6787720528
>             <tel:6787720528>>,7.__3530295908,6.__8599596928 <tel:8599596928>
>                      <tel:8599596928
>             <tel:8599596928>>,7.__2216891568,7.____4951304208,7.__4404728868
>             <tel:4404728868>
>                      <tel:4404728868
>             <tel:4404728868>>,8.__1332243958,6.____2736028029,6.__963685048,6.____0483763169,5.__8653351624
>             <tel:8653351624>
>                      <tel:8653351624 <tel:8653351624>>,5.__6164044005
>             <tel:6164044005>
>                      <tel:6164044005
>             <tel:6164044005>>,6.__54979166,5.__8783224469 <tel:8783224469>
>                      <tel:8783224469
>             <tel:8783224469>>,6.__533468297,5.__8553434082 <tel:8553434082>
>                      <tel:8553434082
>             <tel:8553434082>>,5.__7676662122,6.____267915357,5.__22607939
>             03,3.745459072,6.352470342,5.______4392033722,5.5562602522,5.______3996670482,6.171297855,5.______648779598,5.5653279855,5.______671668653,5.3243595462,5.______879320328,5.859442385
>             <tel:5.859442385>
>                      <tel:5.859442385
>             <tel:5.859442385>>,6.____080574272,5.__3767159992,6.____170852717,5.__3001119472,5.____687201287,5.__3573110752,3.____586385579,5.__566591422,5.____5104826925
>             <tel:5104826925>,5.__916268775,5.____4418422465,5.__4037394705
>             <tel:4037394705>,5.____640889612,5.__1407657702,4.____5523677017,5.__3873769863,3.____601570449,2.__978252449,4.____8725960282
>             <tel:8725960282>,4.__9817842222,5.____2355359365,5.__1227105795,5.____177856607,5.__098596533,5.____1891181988,4.__9327118245,4.____4632330777,7.__4879538737,4.____8591269625,3.__1339054377,5.____8472818275
>             <tel:8472818275>,4.__6043306952
>             <tel:6043306952>,3.____3542942377,4.__7660145915,6.____6679095357
>             <tel:6679095357>,5.__51150886,2.____7404344677
>             <tel:7404344677>,5.__9332075344,6.____2019594857
>             <tel:2019594857>,5.__266709364,5.____4924174224,5.__180577724,3.____0277711677,6.__2913260157,4.____2862670877,5.__5461328154,5.____5809644644
>             <tel:5809644644>,5.__1132029296,5.____1904326724,4.__8352505633
>             <tel:8352505633>,4.____9641930171,5.__1366240426,7.____0699378037,3.__1274712477,5.____1487646306,5.__2717034197,5.____0200090866,3.__0911490977,5.____8984613527,5.__1973381747,4.__
>             2427530627,6.7293864957,4.______7943011637,5.1130266607,5.______3948779287,4.7124246547
>             <tel:7124246547>,5.2
>                           186371577,2.9723417287 <tel:9723417287>
>             <tel:9723417287 <tel:9723417287>> <tel:9723417287
>             <tel:9723417287>
>                      <tel:9723417287
>             <tel:9723417287>>>,2.3171875277,2.8159853427
>             <tel:8159853427> <tel:8159853427 <tel:8159853427>>
>                      <tel:8159853427
>             <tel:8159853427>>>,__4.7913513947,4.7863347867
>             <tel:7863347867> <tel:7863347867 <tel:7863347867>>
>                      <tel:7863347867
>             <tel:7863347867>>>,3.4531342837,__3.____8161332287,5.8431115757,4.______4873126817,5.6577494097
>             <tel:6577494097>,5.______5867970832
>             <tel:5867970832>,9.4583860946
>             <tel:4583860946>,2.______7784615917
>             <tel:7784615917>,5.4279953797,1.______9376872717
>             <tel:9376872717>,5.0813930177,5.______8860618114,6.2411339874,6.______4536904614,6.0972641874,5.______7247963284
>             <tel:7247963284>,5.9823452114,5.______8316140784
>             <tel:8316140784>,5.2398164977
>             <tel:2398164977>,6.______2963392357,5.5864457124,6.______1599995178,5.2609646384,6.______1012355027,6.4129483756,6.______0056487896,5.0106569884,5.______4239402364,6.1148656496,2.______673828844,4.3332873457,3.______2943586634,4.5834393467,7.______278601561,3.5870893269,3.______3299191554,4.1049776549,5.______9256568037,6.2719334873,6.______2594329923,5.5752581689,5.______6058592867,6.1311384893,6.______4726413519,5.8973941434,6.______2572672069,5.9667442136,5.______3965422637,7.2837623985,6.______9586195092,7.1137641952,6.______3682104908,7.8495628418,7.______2245886958,6.2983788278,7.______3509762248,6.9925366658,6.______5600944468,6.936328733,6.______616665943,6.738732443}")
>                      RETURN QUERY
>             line 3 at RETURN
>                      QUERY
>                      RETURN QUERY
>             line 3 at RETURN
>                      QUERY
>                               NOTICE:  ids: <NULL>
>                      RETURN QUERY
>             line 3 at RETURN
>                      QUERY
>             dimensions are not
>                               compatible for
>                               concatenation.
>                      line 25 at
>                               assignment
>             at RETURN QUERY
>             line 3 at RETURN
>                      QUERY
>                               I tried to write to Dose but he didn't
>             reply yet.
>                               Does anyone have a clue?
>                           Try adding the follow line after the "begin" line:
>                           This should make sure the ids is initialized
>             as an empty
>                      array of
>                           integers.
>                           -Steve
>                      Again:
>                      NOTICE:  r2:
>             <tel:3602868897 <tel:3602868897>>,4.6782573327 <tel:6782573327>
>                      <tel:6782573327 <tel:6782573327>>,5.6026971537
>             <tel:6026971537>>,5.2062747797 <tel:2062747797>
>                      <tel:2062747797
>             <tel:2062747797>>,5.__0497181017,5.3147719797
>             <tel:3147719797>,5.____0700916462,4.3220066797,4.__8593618137 <tel:8593618137>,__4.0002255227,6.__055760592,12.__5155379824,9.__3170226155,8.__72783427270001,5.__9460446587,__3.0868131677,5.__1839796057,5.__2301666167,2.__1211198847,5.__7037465591,2.__7282842677,8.__4758437557,11.__1027935904,7.__9434273599,7.__8361619299,7.__7610621969,7.__4929139614,5.__8106133327,5.__9579132527,5.__9888473034,6.__5618433959,4.__5013708887,1.__9218516244,5.__7559805232,5.__2267081177,5.__0968196707,4.__8949133597,5.__9137964962,4.__2936059427,4.__6948533593,3.__4377318427,3.__7991617067,4.__1242444467,3.__8858731777,3.__9596393887,4.__9192685996,4.__6734033563,4.__7511846457,4.__4544981945,4.__2748693367,3.__411559417,6.__6851381985,6.__6744741285,6.__9296475385,7.__0136847108,7.__1371500908,7.__2719520708,6.__6787720528,7.__3530295908,6.__8599596928,7.__2216891568,7.__4951304208,7.__4404728868,8.__1332243958,6.__2736028029,6.__963685048,6.__0483763169,5.__8653351624,5.__6164044005,6
.__54979166,5.__8783224469,6.__533468297,5.__8553434082,5.7
>         676662122,6.__267915357,5.__22607939
>             03,3.745459072,6.352470342,5.____4392033722,5.5562602522,5.____3996670482,6.171297855,5.____648779598,5.5653279855,5.____671668653,5.3243595462,5.____879320328,5.859442385,6.____080574272,5.3767159992,6.____170852717,5.3001119472,5.____687201287,5.3573110752,3.____586385579,5.566591422,5.____5104826925,5.916268775,5.____4418422465,5.4037394705,5.____640889612,5.1407657702,4.____5523677017,5.3873769863,3.____601570449,2.978252449,4.____8725960282,4.9817842222,5.____2355359365,5.1227105795,5.____177856607,5.098596533,5.____1891181988,4.9327118245,4.____4632330777,7.4879538737,4.____8591269625,3.1339054377,5.____8472818275,4.6043306952,3.____3542942377,4.7660145915,6.____6679095357,5.51150886,2.____7404344677,5.9332075344,6.____2019594857,5.266709364,5.____4924174224,5.180577724,3.____0277711677,6.2913260157,4.____2862670877,5.5461328154,5.____5809644644,5.1132029296,5.____1904326724,4.8352505633,4.____9641930171,5.1366240426,7.____0699378037,3.1274712477,5.____1487646306
,5.2717034197,5.____0200090866,3.0911490977,5.____8984613527,5.1973381747,4.__
>         2427530627,6.7293864957,4.____7943011637,5.1130266607,5.____3948779287,4.7124246547,5.2
>                  186371577,2.9723417287 <tel:9723417287> <tel:9723417287
>             <tel:9723417287>>,2.3171875277,2.8159853427 <tel:8159853427>
>                  <tel:8159853427
>             <tel:8159853427>>,__4.7913513947,4.7863347867 <tel:7863347867>
>                  <tel:7863347867
>             <tel:7863347867>>,3.4531342837,__3.__8161332287,5.8431115757,4.____4873126817,5.6577494097,5.____5867970832,9.4583860946,2.____7784615917,5.4279953797,1.____9376872717,5.0813930177,5.____8860618114,6.2411339874,6.____4536904614,6.0972641874,5.____7247963284,5.9823452114,5.____8316140784,5.2398164977,6.____2963392357,5.5864457124,6.____1599995178,5.2609646384,6.____1012355027,6.4129483756,6.____0056487896,5.0106569884,5.____4239402364,6.1148656496,2.____673828844,4.3332873457,3.____2943586634,4.5834393467,7.____278601561,3.5870893269,3.____3299191554,4.1049776549,5.____9256568037,6.2719334873,6.____2594329923,5.5752581689,5.____6058592867,6.1311384893,6.____4726413519,5.8973941434,6.____2572672069,5.9667442136,5.____3965422637,7.2837623985,6.____9586195092,7.1137641952,6.____3682104908,7.8495628418,7.____2245886958,6.2983788278,7.____3509762248,6.9925366658,6.____5600944468,6.936328733,6.____616665943,6.738732443}")
>             8 at RETURN QUERY
>             RETURN QUERY
>             8 at RETURN QUERY
>             RETURN QUERY
>                      NOTICE:  ids: {}
>             8 at RETURN QUERY
>             RETURN QUERY
>             are not
>                      compatible for
>                      concatenation.
>                      assignment
>             RETURN QUERY
>             RETURN QUERY
>                      Thanks for your help. Maybe you need some other
>             facts about my
>                      table?
>                      The whole script I am excecuting is the following.
>             I changed some
>                      things, like adding your code and changing the
>             table name 'ways' to
>                      'cgn_2po_4pgr':
>             integer[])
>                          as
>                      $body$
>                      declare
>                            sql text;
>                            sql2 text;
>                            r record;
>                            r2 record;
>                            i integer;
>                            j integer;
>                      begin
>             arow from (
>                                  FROM
>             pgr_kdijkstraCost('''||sqlP||'____'', '||r.node||
>             '||thetbl||' where
>                      id>'||r.id <http://r.id> <http://r.id>
>                                matrixl := '{}';
>             <http://r.id> <http://r.id> loop
>                      dmatrix[i][r.id <http://r.id> <http://r.id>
>                      <http://r.id>+1]);
>                                        end loop;
>             r2.arow);
>             array[matrixl]);
>                  Sorry, I don't have a running version of this so this
>             is somewhat
>                  guess work.
>                                --  ids := ids || r2.id1;
>                                  ids := array_cat(ids, r2.id1);
>         try changing the line above to:
>     Hi Steve, thank you. Back in office now but I'll try that later at home.
>     I'll let you know and hopefully I get a good result :)
>     Thanks so much.
>     Carsten
>                  So comment out the old like and rewrite like this.
>                  -Steve
>             Thanks for all your help Steve,
>             hope, we're getting closer! Look, not it returns this:
>             NOTICE:  r2:
>             (34304,"{0,5.3602868897 <tel:3602868897>,4.6782573327
>             <tel:6782573327>,5.6026971537 <tel:6026971537>,5.2062747797
>             <tel:2062747797>,5.__0497181017,5.3147719797,5.__0700916462,4.3220066797,4.__8593618137,4.0002255227,6.__055760592,12.5155379824,9.__3170226155,8.72783427270001,5.__9460446587,3.0868131677,5.__1839796057,5.2301666167,2.__1211198847,5.7037465591,2.__7282842677,8.4758437557,11.__1027935904,7.9434273599,7.__8361619299,7.7610621969,7.__4929139614,5.8106133327,5.__9579132527,5.9888473034,6.__5618433959,4.5013708887,1.__9218516244,5.7559805232,5.__2267081177,5.0968196707,4.__8949133597,5.9137964962,4.__2936059427,4.6948533593,3.__4377318427,3.7991617067,4.__1242444467,3.8858731777,3.__9596393887,4.9192685996,4.__6734033563,4.7511846457,4.__4544981945,4.2748693367,3.__411559417,6.6851381985,6.__6744741285,6.9296475385,7.__0136847108,7.1371500908,7.__2719520708,6.6787720528,7.__3530295908,6.8599596928,7.__2216891568,7.4951304208,7.__4404728868,8.1332243958,6.__2736028029,6.963685048,6.__0483763169,5.8653351624,5.__6164044005,6.54979166,5.__8783224469,6.533468297,5.__8553434082
,5.7676662122,6.__267915357,5.22607939
>         03,3.745459072,6.352470342,5.__4392033722,5.5562602522,5.__3996670482,6.171297855,5.__648779598,5.5653279855,5.__671668653,5.3243595462,5.__879320328,5.859442385,6.__080574272,5.3767159992,6.__170852717,5.3001119472,5.__687201287,5.3573110752,3.__586385579,5.566591422,5.__5104826925,5.916268775,5.__4418422465,5.4037394705,5.__640889612,5.1407657702,4.__5523677017,5.3873769863,3.__601570449,2.978252449,4.__8725960282,4.9817842222,5.__2355359365,5.1227105795,5.__177856607,5.098596533,5.__1891181988,4.9327118245,4.__4632330777,7.4879538737,4.__8591269625,3.1339054377,5.__8472818275,4.6043306952,3.__3542942377,4.7660145915,6.__6679095357,5.51150886,2.__7404344677,5.9332075344,6.__2019594857,5.266709364,5.__4924174224,5.180577724,3.__0277711677,6.2913260157,4.__2862670877,5.5461328154,5.__5809644644,5.1132029296,5.__1904326724,4.8352505633,4.__9641930171,5.1366240426,7.__0699378037,3.1274712477,5.__1487646306,5.2717034197,5.__0200090866,3.0911490977,5.__8984613527,5.1973381747,
4.__2427530627,6.7293864957,4.__7943011637,5.1130266607,5.__3948779287,4.7124246547,5.2
>         <tel:9723417287>,2.3171875277,2.8159853427
>         <tel:8159853427>,__4.7913513947,4.7863347867
>         <tel:7863347867>,3.4531342837,__3.8161332287,5.8431115757,4.__4873126817,5.6577494097,5.__5867970832,9.4583860946,2.__7784615917,5.4279953797,1.__9376872717,5.0813930177,5.__8860618114,6.2411339874,6.__4536904614,6.0972641874,5.__7247963284,5.9823452114,5.__8316140784,5.2398164977,6.__2963392357,5.5864457124,6.__1599995178,5.2609646384,6.__1012355027,6.4129483756,6.__0056487896,5.0106569884,5.__4239402364,6.1148656496,2.__673828844,4.3332873457,3.__2943586634,4.5834393467,7.__278601561,3.5870893269,3.__3299191554,4.1049776549,5.__9256568037,6.2719334873,6.__2594329923,5.5752581689,5.__6058592867,6.1311384893,6.__4726413519,5.8973941434,6.__2572672069,5.9667442136,5.__3965422637,7.2837623985,6.__9586195092,7.1137641952,6.__3682104908,7.8495628418,7.__2245886958,6.2983788278,7.__3509762248,6.9925366658,6.__5600944468,6.936328733,6.__616665943,6.738732443}")
>             RETURN QUERY
>             RETURN QUERY
>             NOTICE:  ids: {}
>             RETURN QUERY
>             ERROR:  function array_cat(integer[], integer) does not exist
>             LINE 1: SELECT array_cat(ids, r2.id1)
>             HINT:  No function matches the given name and argument
>             types. You might
>             need to add explicit type casts.
>             QUERY:  SELECT array_cat(ids, r2.id1)
>             CONTEXT:  PL/pgSQL function "pgr_makedijkstramatrix" line 31
>             at assignment
>             SQL Status:42883
>             Hinweis:No function matches the given name and argument
>             types. You might
>             Kontext:PL/pgSQL function "pgr_makedijkstramatrix" line 31
>             at assignment
>             Function does not exist? Still have an idea?
>             Thanks
>             Carsten
>                                end loop;
>                            end loop;
>                      end;
>                      $body$
>             text, sql text,
>                      $body$
>                      declare
>                            sid integer;
>                            eid integer;
>                      begin
>             thetbl, sql )
>                            ids as (
>             asc))-1 as rnum, id
>                                  from (
>                                          from dm
>                                        ) foo
>                            t as (
>             <http://b.id> <http://b.id>
>                                  from pgr_tsp(
>             id=start_id limit
>                      1)::integer,
>             else (select
>                      rnum
>                                       ) a,
>                                       ids b
>                                 where a.id <http://a.id> <http://a.id>
>                            r as (
>             dm.dmatrix[r.rnum[t.seq+1]+1][____r.rnum[(t.seq+1)%array___length(__r.rnum,
>                              from t, dm, r;
>                      end;
>                      $body$
>                      $body$
>                      begin
>             target::integer,
>                      length::double
>                                   start_id, end_id);
>                      end;
>                      $body$
>                      Maybe you've got another idea?
>                      Thank you
>                      Carsten
>                               Thanks for you help
>                               Carsten
>                               2014-02-20 16:24 GMT+01:00 Stephen Woodbridge
>             <mailto:woodbri at swoodbridge>.
>             <mailto:woodbri at swoodbridge>.>______com
>             <mailto:woodbri at swoodbridge.com>>>>>:
>                                    On 2/20/2014 9:41 AM, Stephen
>             Woodbridge wrote:
>                                        Hi Carsten,
>                                        The functions at
>             http://dose.0wnz.at/scripts/________sql/pgroute_tspDijkstra.__sql
>             <http://dose.0wnz.at/scripts/______sql/pgroute_tspDijkstra.sql>
>             <http://dose.0wnz.at/scripts/____sql/pgroute_tspDijkstra.sql>__>
>             <http://dose.0wnz.at/scripts/__sql/pgroute_tspDijkstra.sql>>>
>             <http://dose.0wnz.at/scripts/sql/pgroute_tspDijkstra.sql>>>>
>                                        are not part of pgRouting.
>                                        You need to ask this question to
>             Ivan the
>                      author of the
>                               original
>                                        article.
>                                    Sorry, Dose was the original author.
>                                        You probably need to add some
>             debug statements
>                      to get a
>                               better
>                                        understanding of what the code is
>             doing. For
>                      example in
>                                        pgr_makeDijkstraMatrix before the
>             statement:
>                                        ids := ids || array[r2.id1];
>                                    You could try changing this line to:
>                                    and see if that fixes the problem.
>                                    -Steve
>                                        Add:
>                                        This should show you the
>             progression of how
>                      the array
>                               ids is getting
>                                        built as it appears to be
>             compaining about
>                      that in the
>                               error
>                                        message.
>                                        Hope this helps,
>                                            -Steve
>                                        On 2/20/2014 9:21 AM, Carsten
>             Hogertz wrote:
>                                            Hi everybody, I am new to
>             this list and new to
>                               pgrouting.
>                                            I found the following TSP example
>             http://hardwarefetish.com/513-________pgrouting-dijksta-______travelling-__salesman-problem-______tsp-with-__openstreetmap
>             <http://hardwarefetish.com/513-______pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap>
>             <http://hardwarefetish.com/__513-____pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap
>             <http://hardwarefetish.com/513-____pgrouting-dijksta-__travelling-__salesman-problem-__tsp-with-__openstreetmap>>
>             <http://hardwarefetish.com/____513-__pgrouting-dijksta-____travelling-__salesman-problem-____tsp-with-__openstreetmap
>             <http://hardwarefetish.com/__513-__pgrouting-dijksta-__travelling-__salesman-problem-__tsp-with-__openstreetmap>
>             <http://hardwarefetish.com/513-__pgrouting-dijksta-travelling-__salesman-problem-tsp-with-__openstreetmap>>>
>             <http://hardwarefetish.com/______513-pgrouting-dijksta-______travelling-salesman-problem-______tsp-with-openstreetmap
>             <http://hardwarefetish.com/____513-pgrouting-dijksta-____travelling-salesman-problem-____tsp-with-openstreetmap>
>             <http://hardwarefetish.com/__513-pgrouting-dijksta-__travelling-salesman-problem-__tsp-with-openstreetmap>>
>             <http://hardwarefetish.com/513-pgrouting-dijksta-travelling-salesman-problem-tsp-with-openstreetmap>>>>
>                                            and tried to reproduce the
>             solution.
>                                            Unfortunately I always get an
>             error message.
>                                            My DB is complaining about
>             one of your
>                      functions.
>                                            I got my routing table from
>             osm2po. The
>                      table has
>                               the following
>                                            structure:
>                                            1;”id”;”integer”
>                                            2;”osm_id”;”bigint”
>                                            3;”osm_name”;”character varying”
>                                            4;”osm_meta”;”character varying”
>                                            5;”osm_source_id”;”bigint”
>                                            6;”osm_target_id”;”bigint”;
>                                            7;”clazz”;”integer”
>                                            8;”flags”;”integer”
>                                            9;”source”;”integer”
>                                            10;”target”;”integer”
>                                            11;”length”;”double precision”
>                                            12;”kmh”;”integer”
>                                            13;”cost”;”double precision”
>                                            14;”reverse_cost”;”double
>             precision”
>                                            15;”x1″;”double precision”
>                                            16;”y1″;”double precision”
>                                            17;”x2″;”double precision”
>                                            18;”y2″;”double precision”
>                        19;”geom_way”;”geometry(________LineString,4326)”
>                                            - I installed the functions
>             as mentioned
>                      via SQL
>                               window in
>                                            pgAdmin3
>                                            (copy&paste then excecute)
>                                            - I create and populate the
>             my_route table
>                                            - When it comes to step 5 and
>             I try
>                                            select id,lon,lat from
>                               pgr_tspDijkstraLen(’my_route’, 1260
>                                            ) dj, my_route rt where
>             dj.id2=rt.node;
>                                            my DB warns
>             incompatible arrays
>             element
>                      dimensions
>                               are not
>                                            compatible for
>                                            concatenation.
>                      “pgr_makedijkstramatrix”
>                               line 25 at
>                                            assignment PL/pgSQL function
>                      “pgr_tspdijkstra” line
>                               8 at
>                                            RETURN QUERY
>                                            PL/pgSQL function
>             “pgr_tspdijkstralen”
>                      line 3 at
>                               RETURN QUERY
>             incompatible
>                      arrays SQL
>                               Status:2202E
>             element
>                      dimensions are not
>                                            compatible for
>                                            concatenation.
>                               line 25
>                                            at assignment
>                                            PL/pgSQL function
>             “pgr_tspdijkstra” line 8 at
>                               RETURN QUERY
>                                            PL/pgSQL function
>                      line 3 at
>                               RETURN QUERY
>                                            Do you have any idea what
>             went wrong? I really
>                               really need your
>                                            solutionget working. I would
>             appreciate a lot.
>                                            PS: this text is a copy of
>             what I wrote on
>                      on the
>                               comment
>                                            site of the
>                                            blog where I found the solution.
>                                            BR
>                                            Carsten
>             _______________________________________________________
>                                            Pgrouting-users mailing list
>             Pgrouting-users at lists.osgeo.________org
>                                            <mailto:Pgrouting-users at lists
>             <mailto:Pgrouting-users at lists>.
>             <mailto:Pgrouting-users at lists>.__>____osgeo.org
>             <http://osgeo.org> <http://osgeo.org>
>                               <mailto:Pgrouting-users at lists.
>             <mailto:Pgrouting-users at lists.>____osgeo.org <http://osgeo.org>
>                      <mailto:Pgrouting-users at lists.__osgeo.org
>             <mailto:Pgrouting-users at lists.osgeo.org>>>>
>             http://lists.osgeo.org/________mailman/listinfo/pgrouting-________users
>             <http://lists.osgeo.org/______mailman/listinfo/pgrouting-______users>
>             <http://lists.osgeo.org/____mailman/listinfo/pgrouting-____users>>
>             <http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users>>>
>             <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>>>>
>                               Pgrouting-users at lists.osgeo.______org
>                      Pgrouting-users at lists.osgeo.____org
>             Pgrouting-users at lists.osgeo.__org
More information about the Pgrouting-users mailing list
