[pgrouting-users] (SOLVED) TRSP returns "Start id was not found"
Stephen Woodbridge woodbri at swoodbridge.com
Fri Mar 7 06:24:03 PST 2014
Hi Vladimir,
This is a good catch!
Can you please write a bug on this issue so we remember to resolve it in
the next release.
Glad you got this working.
Thanks,
   -Steve
On 3/7/2014 5:45 AM, Vladimir wrote:
> Hi again.
> As written in the documentation
> <http://docs.pgrouting.org/2.0/en/src/trsp/doc/index.html#trsp>for SQL
> statement of TRSP:
> id:    int4 identifier of the edge
> But  pgr_createTopology function creates new "noded" table with "id" of
> bigint type.
> I've solved this problem by casting "id" to integer type.
> Now that's works:
> SELECT seq, id1 AS node, id2 AS edge, cost FROM pgr_trsp('SELECT
> id::integer,source::integer,target::integer,cost::float FROM edge_tab',
> 138, 0.5, 161, 0.5, false, false);
> Thanks very much to author of this
> <http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-Shortest-Path-TRSP-td3782221.html>
> post for idea.
> Best regards.
>     Hello All!
>     I try to use TRSP with source_edge/target_edge syntax:
>     id,source::integer,target::integer,cost::float FROM edge_tab', 138,
>     but the error "Start id was not found" occurs.
>     Edges with ids 138 and 161 exists in edge_tab that's checked by
>     SELECT * FROM edge_tab WHERE id in (138,161)
>     pgr_version: 2.0.0,pgrouting-2.0.0,0,f26831f,master,1.53.0
>     Please could you tell me what's wrong ?
>     _______________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.org
>     </compose?To=Pgrouting%2dusers at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
