[pgrouting-users] pgr_nodeNetwork ?
Stephen Woodbridge woodbri at swoodbridge.com
Mon Nov 17 14:35:27 PST 2014
On 11/17/2014 3:17 PM, Hugo Mercier wrote:
> Hi all,
> I am trying to use pgr_nodeNetwork to split crossing lines (both
> X-shaped and T-shaped).
> It seems to add way more new nodes than needed. Lines are sometimes
> split right in the middle where there is no reason for that (no
> intersection).
> Playing with the tolerance argument does not seem to solve the issue.
Tolerance needs to be set in the units of your data, ie: if you data is
in WGS84 decimal degrees then you need a tolerance like 0.000001 But if
you data is in meters then a tolerance of 1.0 is probably fine. Of
course this all depends on your data.
If you have lines like
A---------C-B---------D
where the original segments are AB and CD then you will get new segments
AC, CB, BD
There are lots of cases that look fine when you view the data, but are
not so good when we analyze the data. Also if you tolerance is wacky
then there is not telling what might happen.
-Steve
> Is it desgined to be used that way ?
> Am I missing something ?
> Thanks
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
