[pgrouting-users] Problem with query
Worth Lutz wal3 at mindspring.com
Fri Jul 1 11:38:21 PDT 2016
Vicky,
I meant which algorithms have been reworked and which may still have
problems?
I'm working my way through pgRouting to learn the new v2. Much has
changed since I last worked with it and I'm trying to understand the
differences in all the options.
*Worth Lutz*
On 7/1/2016 1:15 PM, Vicky Vergara wrote:
> Worh:
> latest version is always best, so v2.2.3.
> thanks
> Vicky
> On Fri, Jul 1, 2016 at 11:11 AM, Worth Lutz <wal3 at mindspring.com
> <mailto:wal3 at mindspring.com>> wrote:
>     Hi Vicky,
>     How can I tell which ones to use?
>     I've got v2.2.3 of pgRouting.
>     *Worth Lutz*
>     On 7/1/2016 11:45 AM, Vicky Vergara wrote:
>>     Hello Worth,
>>     Unfortunately pgr_bddijkstra has bugs.
>>     I must tell you the history of pgRouting so that you can
>>     understand why:
>>     V2.0 was to gather and reorganize the functions of pgRouting,
>>     preparing for a rewrite, to remove bugs, and unify internal code.
>>     V2.x are rewrites of functions, we are gradually rewriting the
>>     functions and we are basically starting with the ones that are
>>     c++ boost::graph::function based.
>>     pgr_bdDijkstra is not one of them.
>>     If you can this issue to the issue list:
>>     https://github.com/pgRouting/pgrouting/issues
>>     with your data and queries, so that we are able to reproduce,
>>     and when time comes we have a test case when doing the rewrite of
>>     that function.
>>     Vicky
>>     On Fri, Jul 1, 2016 at 10:08 AM, Worth Lutz <wal3 at mindspring.com
>>         Hi All,
>>         Can anyone explain the strange results (see below) I'm getting?
>>         ~$ apt-show-versions postgresql
>>         postgresql:all/trusty-updates 9.3+154ubuntu1 uptodate
>>         ~$ apt-show-versions postgis
>>         postgis:amd64/trusty 2.1.4+dfsg-3~trusty uptodate
>>         ~$ apt-show-versions postgresql-9.3-pgrouting
>>         postgresql-9.3-pgrouting:amd64/trusty
>>         2.2.3-release-ppa1~trusty1 uptodate
>>         The first query gives me 4 values and the second has the
>>         'id2' value empty.
>>         SELECT
>>             pgr_bdDijkstra(
>>             'SELECT id_base AS id, source, target, cost_len AS cost,
>>         rcost_len AS reverse_cost FROM _rt_geom_streets_base',
>>             11, 6, TRUE, TRUE
>>                  pgr_bddijkstra
>>          (0,11,2087858,482.722955703)
>>          (1,3549,2082803,275.837140233)
>>          (2,24976,2086339,272.953707069)
>>          (3,20623,2086101,484.096255058)
>>          (4,48115,2085508,388.315542378)
>>          (5,47218,2084557,480.30350456)
>>          (6,8387,2094458,476.8149761)
>>          (7,248,2093906,255.35844989)
>>          (8,1348,2097029,247.294429215)
>>          (9,1536,2090136,339.718631568)
>>          (10,6465,2091005,330.978413622)
>>          (11,3740,2087980,415.137012292)
>>          (12,1504,2095856,375.236169771)
>>          (13,1505,2090458,466.482679764)
>>          (14,1130,2089855,481.831396537)
>>          (15,1116,2089664,470.256648783)
>>          (16,1117,2139494,262.774003918)
>>          (17,2907,2139496,73.1337200735)
>>          (18,765,2131538,172.32970181)
>>          (19,6,-1,0)
>>         (20 rows)
>>         SELECT *
>>           FROM
>>         pgr_bdDijkstra(
>>             11, 6, TRUE, TRUE
>>          seq |  id1  | id2 |     cost
>>            0 |    11 |     | 482.722955703
>>            1 |  3549 |     | 275.837140233
>>            2 | 24976 |     | 272.953707069
>>            3 | 20623 |     | 484.096255058
>>            4 | 48115 |     | 388.315542378
>>            5 | 47218 |     |  480.30350456
>>            6 |  8387 |     |   476.8149761
>>            7 |   248 |     |  255.35844989
>>            8 |  1348 |     | 247.294429215
>>            9 |  1536 |     | 339.718631568
>>           10 |  6465 |     | 330.978413622
>>           11 |  3740 |     | 415.137012292
>>           12 |  1504 |     | 375.236169771
>>           13 |  1505 |     | 466.482679764
>>           14 |  1130 |     | 481.831396537
>>           15 |  1116 |     | 470.256648783
>>           16 |  1117 |     | 262.774003918
>>           17 |  2907 |     | 73.1337200735
>>           18 |   765 |     |  172.32970181
>>           19 |     6 |     |             0
>>         (20 rows)
>>         *Worth Lutz*
>>         _______________________________________________
>>         Pgrouting-users mailing list
>>         Pgrouting-users at lists.osgeo.org
>>         <mailto:Pgrouting-users at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>>     Georepublic UG (haftungsbeschränkt)
>>     Salzmannstraße 44,
>>     81739 München, Germany
>>     Vicky Vergara
>>     Operations Research
>>     eMail: vicky at georepublic.de <http://georepublic.de>
>>     Web:https://georepublic.info
>>     Tel: +49 (089) 4161 7698-1
>>     Fax: +49 (089) 4161 7698-9
>>     Commercial register: Amtsgericht München, HRB 181428
>>     CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20160701/86203a98/attachment-0001.html>
More information about the Pgrouting-users mailing list
