[pgrouting-users] dijkstra for MANY sources
Stephen Woodbridge woodbri at swoodbridge.com
Mon Nov 14 14:08:12 PST 2016
On 11/14/2016 2:12 AM, Brian DeRocher wrote:
> Hey there,
> Can someone give me some guidance.  I'm looking for the right
> algorithm to use when solving this problem.  I want to find the
> distance and shortest path to 11 schools for about 15,000 students.
> Does the many to many flavor of dijkstra scale up to these numbers?
> Is there a better way to solve this?
Hi Brian,
Checkout
http://docs.pgrouting.org/2.2/en/src/dijkstra/doc/pgr_dijkstraCost.html
It has a many to one function.
Regarding performance, that depends on a lot of issues but I would think
if your limiting your edge table to the roads in the school district
that you should get reason able performance.
You might want to try running it with 10, 100, 1,000, 15,000 so you have
some idea of the performance at various numbers of nodes.
you will need to map the locations to the node ids in the network, then
pass the node ids to the function.
Ask if you need more explicit help.
-Steve W
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
More information about the Pgrouting-users mailing list
