[pgrouting-users] Build Failure of 2.5.1 on Ubuntu 16.04 (Docker)
Vicky Vergara vicky at georepublic.de
Fri Nov 10 11:35:33 PST 2017
Hello Andrew,
I think its the same issue as here,
Can you try the solutions I posted and give me feedback, so that I can make
a patch
https://github.com/pgRouting/pgrouting/issues/963
Vicky
On Thu, Nov 9, 2017 at 8:20 PM, Andrew Joseph <ap.joseph1337 at gmail.com>
wrote:
> Getting the following error building PG Routing 2.5.1 on Ubuntu 16.04
> [ 49%] Building C object src/alpha_shape/src/CMakeFiles/alpha_shape.dir/
> alpha.c.o
> /tmp/pgrouting/src/alpha_shape/src/alpha.c: In function ‘alphashape’:
> /tmp/pgrouting/src/alpha_shape/src/alpha.c:287:16: error: ‘DBL_MAX’
> undeclared (first use in this function)
>        if (x == DBL_MAX && y == DBL_MAX) {
> /tmp/pgrouting/src/alpha_shape/src/alpha.c:287:16: note: each undeclared
> identifier is reported only once for each function it appears in
> src/alpha_shape/src/CMakeFiles/alpha_shape.dir/build.make:62: recipe for
> target 'src/alpha_shape/src/CMakeFiles/alpha_shape.dir/alpha.c.o' failed
> make[2]: *** [src/alpha_shape/src/CMakeFiles/alpha_shape.dir/alpha.c.o]
> Error 1
> make[1]: *** [src/alpha_shape/src/CMakeFiles/alpha_shape.dir/all] Error 2
> CMakeFiles/Makefile2:555: recipe for target 'src/alpha_shape/src/
> CMakeFiles/alpha_shape.dir/all' failed
> Makefile:127: recipe for target 'all' failed
> make: *** [all] Error 2
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20171110/a9e58e97/attachment.html>
More information about the Pgrouting-users mailing list
