[pgrouting-users] pgr_maxFlow
Vicky Vergara vicky at georepublic.de
Mon Sep 25 06:46:54 PDT 2017
Hi all,
Sorry for the late response.
Initially was under the "Experimental" category, I went through the code,
cleaned code & fixed pgr_edgeDisjointPaths that is why there is a:
Breaking change on:
   - pgr_edgeDisjointPaths:
      - Added path_id, cost and agg_cost columns on the result
      - Parameter names changed
   - The many version results are the union of the one to one version
And I moved them up to the "Stable" section.
On version 2.x only the the functions on 2.0 are in the main area of the
documentation, everything new either is "Stable" or "Experimental"
The Stable ones are the most likely to be moved to the main area of the
documentation on version 3.0
Everything done by GSoC Students is on experimental section unless there
has being a procedure like the one I did on the max flow functions.
And, like Daniel mentioned, feedback is important.
And you are not on your own, i've being feeling that way for this last 2
years of code rewrite, but now I am into a point where I think the internal
code is stable and more members of the community can participate in bug
fixing, more rewriting, or adding new functions with ease. For example,
currently, I am on gitter [1], I am still working with Vidham, and Anthony
Tasca, with the focus on the functions needed to make pgr_trsp work
correctly.
A way to learn how pgRouting works internally & contribute would be to read
code and document the code. (Just by reading 2.0 code I knew it had bugs)
Vicky
[1] https://gitter.im/pgRouting/pgrouting
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20170925/dadab4cd/attachment.html>
More information about the Pgrouting-users mailing list
