[postgis-devel] pg7.3devel
redmonde at purdue.edu redmonde at purdue.edu
Sun Aug 18 17:19:57 PDT 2002
In postgis.sql to be compatable with the upcomming version of postgres I had to change, ALTER TABLE CHECKS from (''||column_name||''=NULL) to
(''||column_name||'' IS NULL).
DropGeometryColumn(varchar,varchar,varchar) line 32.
AddGeometryColumn(varchar,varchar,varchar,integer,varchar,integer) line 50.
Eric
