[postgis-devel] postgis_debug.c function not returning void
Dave Blasby dblasby at refractions.net
Fri Sep 20 11:14:01 PDT 2002
Mark,
The entire postgis_debug.c file is just junk that I've used to verify
the correctness of some of the other functions.  There's nothing
important in it - I should probably delete it from the distribution.
You can just remove the "return" call.  I've committed this to the CVS
archive.
The DOS cr/lf are because I wrote postgis using MS wordpad.  I've got
nothing
but grief from this!  There shouldnt be any in the CVS version.
Mark Sutton wrote:
> The Sun compiler borks on this. :-(
> All the rest of the returns in the function are void.
> Is there some reason the packaged code has DOS end of line
> characters. The CVS checkout fixed this of course .. H'm maybe it's a
> sneaky way to get everyone to use the CVS server.
> I've only started looking at the functions provided by this package
> and they have already let me do some things I could never have done
> without. Very Cool!
