[postgis-devel] Re: [postgis-users] Performance and memory problems
David Blasby dblasby at refractions.net
Fri Dec 5 09:11:21 PST 2003
So, what is the multi-geometry it's failing on?
I dont think this is a recursion problem - it shouldnt be recursing to a
depth more than 2 (the original multi* and the sub-component it's
working on).
It most likely that there's a problem with the collector function or
that GEOS is giving back garbage.
dave
