[postgis-devel] Re: [geos-devel] Proposals for ensuring correct semantics?
strk
strk at keybit.net
Fri Dec 12 02:27:26 PST 2003
dblasby wrote:
> strk wrote:
> > About the buffer semantics I don't think geos should behave differently
> > from JTS, we just tried to use it for debugging purposes. I'll change
> > it back to previous behaviour.
> Add a very simple GEOSnop() function that does a postgis->GEOS->postgis
> convertion.
GEOSnoop committed. SQL create function is in postgis enabler, here
is a copy for quick reference:
CREATE FUNCTION geosnoop(geometry) returns geometry as
'$libdir/libpostgis.so', 'GEOSnoop'
LANGUAGE 'C' WITH (isstrict);
GEOSnoop latest bogus runs:
(1)
INPUT: GEOMETRYCOLLECTION(
LINESTRING(0 0,1 1),LINESTRING(0 0,1 1),
OUTPUT: MULTILINESTRING(
(0 0,1 1),(0 0,1 1),
(0 0,1 1),(0 0,0 0) <-- LAST POINT SHOULD BE 1 1 !
(2)
INPUT:
(0 0,10570.75 1.39069240546547e-309) <-- NOT ALLOC'D ?
NOTE that enabling debugging will should you the correct output
right before GEOSnoop returns. It seems like at GEOSnoop
PG_RETURN_POINTER call some memory is released that
(erroneously?) contained the last part of our geometry.
--strk
