[postgis-devel] Re: postgis front-end interface
strk strk at keybit.net
Tue Nov 18 10:27:26 PST 2003
What about a "privately" available version for use by loader and dumper
then ? I'm just trying to keep code base small and reuse a WKT/WKB codec
with loader, dumper and future converters (SVG,GML).
--strk;
pramsey wrote:
> strk wrote:
> > Trying to do WKB crunching for loader/dumper I came to this conclusion:
> > postgis objects and functionality should be also available for front-end
> > applications.
> > If we can handle GEOMETRY objects and convert them to/from WKB/WKT
> > we will also be able to quickly write any convertion tool (eg. SVG).
> As Dave said, passing postgis geometries no the wire is antithetical to
> OpenGIS principals. A possibly better approach would be to add a
> WKB-based constructor to GEOS, so that data can be read right off the
> wire as WKB and very easily converted into GEOS objects at the client.
> This is true of all client libs, of course. :)
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
