[postgis-devel] dumper and WKB
strk strk at keybit.net
Wed Nov 26 08:02:31 PST 2003
I've committed latest changes to dumper.
<ReportStart>
WKB parsing is disabled by default, to enable
it set USE_WKB define to 1 (or whatever else).
*SPEED ISSUE*
Slowness is mainly due to conversions, currently:
GEOMETRY->binWKB->hexWKB->bytea->binWKB
I've tried making my own HexDecoder to reduce this to:
GEOMETRY->binWKB->hexWKB->binWKB
but it is failing...
Best would be to avoid hex encoding as in:
GEOMETRY->binWKB
And this was the initial idea.
Anyway, this would require a double table scan since a BINARY cursor
would not be adeguate for other data types (for endiannes issues).
I will implement this, but WKB parsing will not change, so if you can
give it a try now your tests will not be a waste of time.
*CORRECTNESS ISSUE*
As far as I can tell it is working, so we should not have dataloss
now. Can you test it ?
*NULL HANDLING*
There is currently no NULL handling. I have a question here:
Are EMPTY geometries encoded in WKB, and how ?
</ReportEnd>
Thanks for your attention
--strk;
