[postgis-devel] GeometryFromWKB
Martin Schäfer Martin.Schaefer at cadcorp.com
Thu Oct 23 01:04:49 PDT 2003
The PostGIS online documentation mentions a function 'GeometryFromWKB' under 'Other functions'.
However, when I try to use it, e.g. like this:
select AsText(GeometryFromWKB('010100000000000000000024400000000000003440'::wkb, 4326));
I well get the error message:
ERROR:  Function geometryfromwkb(wkb, integer) does not exist
        Unable to identify a function that satisfies the given argument types
        You may need to add explicit typecasts
Is this function not yet implemented? If not, then when is it going to be implemented? I believe that GeometryFromWKB() would be a lot faster than GeometryFromText() when a large number of geometries (e.g. > 100,000) are inserted into a table. Is there any chance that it will be implemented soon?
The PostGIS version I'm using is 0.7, PostGreSQL is 7.3.4.
Best regards,
Martin Schäfer
Senior Software Engineer
Cadcorp
Computer Aided Development Corp. Ltd.
4 Fitzroy Square, London, W1T 5HQ
Tel: +44 (0) 20 7383 0015
Fax: +44 (0) 20 7388 6313
martin.schaefer at cadcorp.com
www.cadcorp.com <file:///C:/Documents%20and%20Settings/martins/Application%20Data/Microsoft/Signatures/www.cadcorp.com>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20031023/641a08cb/attachment.html>
