[postgis-devel] Re: [HACKERS] GiST -- making my index faster makes is slower
David Blasby dblasby at refractions.net
Mon Apr 19 13:41:11 PDT 2004
I tracked the problem down to the "penalty" function used to build the
tree.   Basically, it compares the area of the bounding boxes.
There wasnt enough precision in the area calculations - instead of
giving 0.0 it would give numbers in the[+-]10^-6 range.  This really
screwed up how the tree was being built.
I cast the float to doubles when calculating area, and it all works well
now.
dave
