[postgis-devel] LWGEOM -- inital version ready for testing
David Blasby dblasby at refractions.net
Thu Apr 29 11:52:12 PDT 2004
There's an inital version of LWGEOM available for testing.  The indexes
it makes are about 40% smaller, and there's a very significant reduction
of the actual geometry size.  It natively supports 2D, 3D, and 4D
geometries.
Its been tested on a Linux (Intel) machine and a Solaris (Sparc)
machine.  Norman says it compiles on Windows (cygwin), so it should also
work there.
If you checkout a CVS copy of PostGIS, you'll see a "lwgeom/" directory.
There's a README file here with lots of details on how to use it.
In summary, to test out the LWGEOM on your system:
      cd lwgeom
      make
      cd regress
      ./run_regress
      ./run_regress2
      ./run_regress3
Please let me know if you're tried it out and if you had any problems.
dave
ps. I've attached the README file - it contains more detail of how to
use the LWGEOM type.
pps. Thanks to Ralph Mason who did lots of work doing a lex/yacc WKT/WKB
parser and writers.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20040429/71369365/attachment.ksh>
