[postgis-devel] Z() function
David Blasby dblasby at gmail.com
Wed Aug 11 10:13:21 PDT 2004
This is a bug - are you using a recent version?  I think this was
fixed early this year.
If its still there, we need to fix it.
What type of machine are you running on?
dave
On Wed, 11 Aug 2004 12:43:59 -0400, Carl Anderson
<carl.anderson at co.fulton.ga.us> wrote:
> David Blasby wrote:
> >It should be returning 0.
> >PostGIS stores everything as x,y,z points.  If you give it only (x,y)
> >it'll set z to 0.
> >The LWGEOM objects are smarter about this.
