[postgis-devel] length{,2d,3d}
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Aug 25 03:56:49 PDT 2004
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Martin Daly
> Sent: 25 August 2004 11:36
> To: PostGIS Development Discussion
> Subject: RE: [postgis-devel] length{,2d,3d}
> Mark,
> > This is definitely an interesting issue that you've raised.
> > I've just had a look over the OpenGIS specification and
> > looking at section 2.1.3.1 it would appear that the entire
> > spec is only written based on a 2D point :/. The other
> The attached OGC document (which was adopted some time ago)
> is an addendum to the Simple Features specification which covers 2.5D.
> Regards,
> Martin
Hi Martin,
Thanks for the pointers, as you suspected I was still looking at just
the original spec PDF. The case of a 2D -> 3D cast doesn't appear to be
a problem, however it looks like there are some interesting functions to
write around the spatial operators, for example collapsing a 3D geom to
2D, calculating the difference, and then interpolating the result back
into 3D.... does GEOS already do this? :)
Cheers,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
