[postgis-devel] length{,2d,3d}
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Wed Aug 25 05:10:35 PDT 2004
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Martin Daly
> Sent: 25 August 2004 12:01
> To: PostGIS Development Discussion
> Subject: RE: [postgis-devel] length{,2d,3d}
> Mark,
> > Thanks for the pointers, as you suspected I was still looking
> > at just the original spec PDF. The case of a 2D -> 3D cast
> > doesn't appear to be a problem, however it looks like there
> > are some interesting functions to write around the spatial
> > operators, for example collapsing a 3D geom to 2D,
> > calculating the difference, and then interpolating the result
> > back into 3D.... does GEOS already do this? :)
> The document addresses this in section 3.1.4, below.
> Regards,
> Martin
Hi Martin,
Sorry I obviously didn't ask my question in the right way; what I was
looking for was confirmation that GEOS could do this transformation,
i.e. does GEOS do the 3D <-> 2.5D conversion according to the spec, or
does it only accept 2D coordinates?
Kind regards,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
