[postgis-devel] Query causes Postgres to crash
strk at refractions.net strk at refractions.net
Fri Dec 10 08:11:36 PST 2004
Collin.. I've also found a crash bug report which might be the cause
of your problem:
I'm sorry didn't search on the web, here are info to find out
yourself:
> Date: Fri, 05 Nov 2004 15:46:53 -0500
> From: Tom Lane <tgl at sss.pgh.pa.us>
> Subject: Re: [HACKERS] Backend 8.0.0B4 crash on SELECT ...
Contains a patch and has to do with estimators code...
Beta5 is out, maybe you can also test that.
I've made a simple test locally and my explain analyze is also
hung with a much smaller dataset (beta4 here).
--strk;
On Thu, Dec 09, 2004 at 10:48:42AM -0800, collin wrote:
> Folks, the following query has consistantly caused Postgresql 8.0beta4
> to crash (postgis 1.0cvs (10/15/04),geos 2.0.1,proj4.4.9) on a FC3 linux
> pc (1GB ram, 160GB HD, dual 750mhz PIII).
> UPDATE grid10m SET
> lzmin = (SELECT min(lz) from unfilteredpts WHERE lreturn  && the_geom),
> lzmax  = (SELECT max(lz) from unfilteredpts WHERE lreturn  && the_geom),
> lzavg  = (SELECT avg(lz) from unfilteredpts WHERE lreturn  && the_geom),
> lzstddev  = (SELECT stddev(lz) from unfilteredpts WHERE lreturn  &&
> the_geom);
> grid10m is a set of 11,000 square polygons.  unfilteredpts is as set of
> 2.5 million points (2 geometry columns lreturn, freturn).
> I am trying an explain analyze on a subset (1,700 grid polys & 400,000
> pts), but it has been 2 hours and I still do not have a result.
> Any thoughts? Thanks,
> Collin
> NCALM/NCED, UC Berkeley
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
