[postgis-devel] GEOS2POSTGIS
Carl Anderson carl.anderson at co.fulton.ga.us
Tue Dec 14 06:33:17 PST 2004
strk at refractions.net wrote:
>On Mon, Dec 13, 2004 at 02:18:11PM -0500, Carl Anderson wrote:
>>I am having problems with MULTIPOLYGON types passing through GEOS2POSTGIS
>>the routine is making a geometry collection of polygons not a multipolygon
>>except that it labels the mess as a multipolygon
>>for example
>>SRID=102667;010600000005000000SRID=0;0103000000010000000500000000
>>0000606EA1404100000020825A3441207F245077A1404153CCD639995A3441
>>2CF237915CA14041859B332C505A344139A6505F76A140416E660BA8965A3
>>441000000606EA1404100000020825A3441SRID=0;010300000001............
>>not
>>SRID=102667;0106000000050000000103000000010000000500000000
>>441000000606EA1404100000020825A3441010300000001............
>IIRC a MULTIPOLYGON is exactly a collection of polygons
>labeled as a multipolygon. The problem here is with SRID defined
>inside inner geoms.
sorry i meant a collection of lwgeom polygons as opposed to a collection
of OGC polygons. OGC WKB/WKT lack the tag SRID
>I've taken a look at the 'collect' function and it failed
>to check for compatible dimensions and srid. I've added that.
>But how did you produce that geometry ? Solely inside GEOS ?
>In that case we need to check it somewhere else.
Postgresql:
select difference(a.the_geom,b.the_geom) from a, b .....
current CVS is working  ok.
C.
Carl Anderson
GIS Manager Fulton County, Georgia
404.730.8026
This message has been scanned for viruses and
dangerous content for Fulton County by DefendMail, and is
believed to be clean.
