[postgis-devel] Bug in current CVS with GEOSnoop without GEOS
strk at refractions.net strk at refractions.net
Fri Dec 17 03:07:26 PST 2004
On Fri, Dec 17, 2004 at 10:23:02AM -0000, Mark Cave-Ayland wrote:
> Hi guys,
> Just downloaded and installed the latest PostGIS CVS on a Linux machine
> without GEOS (set USE_GEOS=0 in the Makefile). When I tried to insert
> lwpostgis.sql, I got the following error:
> psql:lwpostgis.sql:2873: ERROR:  could not find function "GEOSnoop" in file
> "/home/pg80b2/rel/lib/postgresql/liblwgeom.so.1.0"
> So it looks as if GEOSnoop is still being defined in the sql file, even when
> specifying a build without GEOS in the Makefile. Other than that, looking
> good, so I shall carry on with some more testing.....
Fixed, thanks.
I've also fixed some endian checks, so you might want to update
and re-install.
Welcome in LWGEOMland Mark, I hope you'll help us on the canonical
binary issue being discussed.
--strk;
> Kind regards,
> Mark.
> WebBased Ltd
> South West Technology Centre
> Tamar Science Park
> Plymouth
> PL6 8BT
> T: +44 (0)1752 791021
> F: +44 (0)1752 791023
> W: http://www.webbased.co.uk
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
