[postgis-devel] Installing PostGIS CVS
strk at refractions.net strk at refractions.net
Fri Dec 17 09:58:16 PST 2004
Thank you Markus,
both issues fixed.
--strk;
On Fri, Dec 17, 2004 at 04:34:43PM +0100, Markus Schaber wrote:
> Hi, strk,
> I just had my first try at installing current PostGIS CVS HEAD, this are
> my experiences:
> First, the following patch fixes the libgeos/Makefile on a fresh CVS checkout
> where the eXecute permission bit is not set:
> Index: lwgeom/Makefile
> RCS file: /home/cvs/postgis/postgis/lwgeom/Makefile,v
> retrieving revision 1.49
> diff -u -r1.49 Makefile
> --- lwgeom/Makefile     13 Dec 2004 13:04:41 -0000      1.49
> +++ lwgeom/Makefile     17 Dec 2004 15:12:16 -0000
> @@ -146,7 +146,7 @@
>  detect_geos_version:
> -       ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
> +       sh ../geos_version.sh $(GEOS_DIR) > postgis_geos_version.h
>  installdirs:
>         $(mkinstalldirs) $(libdir)
> Then, after fixing my pathes in Makefile.config, compiling and make
> install went fine, apart from loads of warnings. Most of them are tsort
> complaining about loops.
> But then, running the lwpostgis.sql fails with the following error:
> psql:/usr/share/postgresql/lwpostgis.sql:432: ERROR:  could not find
> function "LWGEOM_gist_joinsel" in file
> "/usr/lib/postgresql/lib//liblwgeom.so.1.0"
> It seems that LWGEOM_gist_joinsel currently is only implemented for pg8,
> so current CVS does not work with postgis 7.4.
> HTH,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
