[postgis-devel] polygonize
strk at refractions.net strk at refractions.net
Mon Dec 20 02:14:01 PST 2004
On Sun, Dec 19, 2004 at 02:09:56PM -0500, Carl Anderson wrote:
> strk at refractions.net wrote:
> >On Sun, Dec 19, 2004 at 11:22:09AM -0500, Carl Anderson wrote:
> >>btw
> >>select polygonize_garray(array_append('{}',the_geom) from shapes;
> >>Causes a backend ABEND;
> >Does collect_garray(array_append('{}',the_geom) from shapes work ?
> >--strk;
> That also ABENDs the backend;
> C.
This is an old problem. The problem is that collect_garray expects
an array of PG_LWGEOM *pointers*, while array_append builds an array
of PG_LWGEOM *toasts*.
Those queries should work if written as:
 select polygonize_garray(geom_accum('{}',the_geom) from shapes;
 select collect_garray(geom_accum('{}',the_geom) from shapes;
--strk;
> >> C.
> >>_______________________________________________
> >>postgis-devel mailing list
> >>postgis-devel at postgis.refractions.net
> >>http://postgis.refractions.net/mailman/listinfo/postgis-devel
