[postgis-devel] Re: [HACKERS] join selectivity
strk at refractions.net strk at refractions.net
Thu Dec 23 01:33:51 PST 2004
On Thu, Dec 16, 2004 at 01:56:29PM -0500, Tom Lane wrote:
> "Mark Cave-Ayland" <m.cave-ayland at webbased.co.uk> writes:
> > ... But in the case of <column> <op>
> > <unknown constant>, if we're estimating the number of rows to return then
> > that becomes harder
> I didn't say it was easy ;-).  The existing selectivity functions can't
> do better than a rough guess in such cases, and I don't expect you can
> either.
Tom, correct me if I'm wrong.
Doing some tests I've found out that the returned value from the
JOINSEL is applied to REL1.rows X REL2.rows, but REL1 and REL2
are not 'base' table, rather relations with a number of
rows once again estimated by other selectivity functions.
For example, if JOINSEL always returns 1.0, you get a different
'estimated' number of rows for a Nested Loop depending on the
presence of a condition filtering one of the tables.
Example:
	test1 has 34 rows
	test2 has 32 rows
	a full join makes the estimate=1088 rows  ( 34*32  )
	a join with a filter on test2 makes estimate=34 ( 34*1 ? )
strk=# explain analyze select * from test1, test2 where test1.geom && test2.geom;
NOTICE:  LWGEOM_gist_joinsel called (returning 1.000000)
                                                  QUERY PLAN
 Nested Loop  (cost=3.37..32.17 rows=1088 width=36) (actual time=0.193..70.691 rows=983 loops=1)
   Join Filter: ("inner".geom && "outer".geom)
   ->  Seq Scan on test2  (cost=0.00..4.32 rows=32 width=4) (actual time=0.074..0.267 rows=32 loops=1)
   ->  Materialize  (cost=3.37..3.71 rows=34 width=32) (actual time=0.002..0.026 rows=34 loops=32)
         ->  Seq Scan on test1  (cost=0.00..3.34 rows=34 width=32) (actual time=0.042..0.159 rows=34 loops=1)
 Total runtime: 71.426 ms
(6 rows)
trk=# explain analyze select * from test1, test2 where test1.geom && test2.geom and test2.id = 1;
                                               QUERY PLAN
 Nested Loop  (cost=0.00..8.17 rows=34 width=44) (actual time=0.179..2.704 rows=17 loops=1)
   ->  Seq Scan on test2  (cost=0.00..4.40 rows=1 width=8) (actual time=0.078..0.208 rows=1 loops=1)
         Filter: (id = 1)
   ->  Seq Scan on test1  (cost=0.00..3.34 rows=34 width=36) (actual time=0.041..0.181 rows=34 loops=1)
 Total runtime: 2.819 ms
(6 rows)
	Now, is the number 1 what has been estimated by
	the RESTRICT selectivity estimator for
	SERIAL = <constant> ?
	If it is, does our JOINSEL function have access to this
	information ?
TIA
--strk;
