[postgis-devel] automatic BVOL on spatial columns
strk at refractions.net strk at refractions.net
Thu Dec 30 05:02:02 PST 2004
On Wed, Dec 29, 2004 at 04:00:04PM -0800, Paul Ramsey wrote:
> If your only/main worry is that we are taking away configurability from
> the user, then you should cease worrying. Too much configurability can
> be a *bad* thing, in the hands of people who do not want to have it. It
> forces them to make a bunch of decisions about things that they really
> do not want to know about, right away when they are still trying to
> learn basic things about the software.
> What we want is a default configuration that "works pretty good", and
> without *any* special knowledge or configuration on the part of the user
> about abstract things like bbox caching strategies and their consequences.
> If we make configurable caching a compile-time option or "special fiddly
> runtime" option, we can document how to use it, and the 1% of users who
> want to wring every last drop of performance out of their installations
> can read it and figure how to use it.
> The rest will not know, will not care, and will live longer happier lives.
> Paul
Ok. Point taken.
I'll go through the process of enforcing bbox caching based
on some heuristic. What I can think of is a function taking
care of applying the hauristic to PG_LWGEOM and LWGEOM objects.
Here is a question: should a geometry for which cache conditions
are not met loose an eventually already present bbox ?
--strk;
> strk at refractions.net wrote:
> >>Also, this logic should be left to the user, so she can decide when to
> >>cache and when not to. She might want fast load and successive
> >>bbox caching, she might want to cache bbox only on indexed tables,
> >>or only for geoms with npoints > X in a table and > Y in another.
> >>I just don't see an easy way though :(
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
For standing up against patentability of software,
  Thank You, Poland!
Read the intervention:    http://kwiki.ffii.org/ConsPolon041221En
Send your thanks:         thankyoupoland.info
Read/do more:		  http://www.noepatents.org/
