[postgis-devel] Re: geometry stats
David Blasby dblasby at refractions.net
Tue Feb 24 16:58:31 PST 2004
> 	3) is there a test suite to help tuning the estimator ?
> 	   [ this is for Dave ]
Not really - I tested it by looking at the data in the histogram (to
make sure the histogram was being calculated properly - see below), then
looking at the actual stats (EXPLAIN ANALYSE) vs actual results.
I have *no* idea how well it will work based on a sample size of 3000.
You could have it do the old-style calculates as well as the new-style
and have it spit out both results ( "elog(NOTICE,"...",..,..,..);").
There was some work done with random bounding boxes and checking the
estimates, but I cannot find it.
SELECT count(*) FROM <table> WHERE the_Geom && <test bbox>
SELECT estimate_histogram(<histogram>, <test bbox>);
> 	5) how do we compose the bits we have: cell_area, box_area, AOI,
> 	   cell_value, avgFeaturesArea to get a nice picture ;) ?
> 	5bis) how do we see the nice picture ? (see point 3)
The original stats package had an explode_histogram() function that
would create a table with the contents of the histogram.  I used
pgsql2shp and loaded the histogram and dataset into arc-view and checked
the results.
If you use arc-view (or jump) you can colour the histogram polygons
based on the # of items in the box - this makes it easy to view.  I used
a roads dataset to test since its so highly skewed.  Turning both layers
  on at the same time should show a dark (lots of geometries) box around
the vicinity of the cities, and light-coloured in other areas.
//explode_histogram2d(histogram2d, tablename::text)
// executes CREATE TABLE tablename (the_geom geometry, id int, hits int,
percent float)
// then populates it
//  DOES NOT UPDATE GEOMETRY_COLUMNS
The geometry is a polygon (representing the box).  Make sure you drop
the exploded histogram table before you run the function or you'll get
an error.
dave
